Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Ultimate Care II washer will not agitate or spin
My Ultimate Care II Heavy Duty Super Capacity Plus washer will not agitate or spin. Is there something I can do to further narrow down the problem and get this fixed?
    President:
  • 949 Answers
It sounds like it may be a coupling issue. Follow the link I attached for instructions I put together about the coupling and how to replace it. If you have questions let me know
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Posted on May 08, 2010
  • Whirlpool Master
  • 8,220 Answers
Your lid switch could be the problem. It has 3 wires: black red which are hot and green which is ground. Unplug that lid switch and check for continuity between black and red with the lid shut. This video shows where the lid switch is located
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool heavy duty super capacity plus is acting funny. it will run water and then it i will not spin and will not drain water. it will agitate, but when it does it makes a funny noise. what could be...
Could be a few problems. Bad lid switch could be the problem but also could be other things. The agitator noise is something probably you should let a technician hear it could be as bad as a bad transmission. That could also be the cause of the other.
Dec 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
543 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
