Question about Dell XPS 400 Dual Core 2.8Ghz, 512MB, 160G, 128M ATI, DVDRW & DVDXPS400 PC Desktop
Black screen when powered up
Black screen says driver 5 not found press f1 to continue f5 for something else then if I hit f1 to continue it says auto adjusting then nothing just a black screen and doesn't even get to the welcome pg where you can log in, any solutions would be appreciated
  • 345 Answers
I would try booting in to safe mode by tapping F8 key on reboot and see does it come up. If it does means bad driver and by what it sounds like it might be display driver. When and if you choose safe mode do safe mode with networking so you can go online and update drivers. Hope this helps.
Posted on May 08, 2010
My daughters desk top computer will boot up when I press f1 and then it shuts down and brings me back to a black screen and tells me to hit f1 and reboots. When the windows does come up I dont have time to...
Remove the battery from the motherboard and check that it has 3volts or above. if not then replace it. That will cure your pressing F1 to continue all the time. As for the restarts then you will need to turn off Automatically restart in the control panel,system section. To do this you will need to boot into safe mode. Tap the F8 while booting until you get a black screen with white type on it. Its first option is to boot into safe mode. hit enter on this screen and windows will start with no drivers loaded. the screen will appear very large. navigate to the control panel as mentioned above and untick "automatically restart". Ok that and reboot normally. now you will most probably get a blue screen of death. note the first stop code. it will appear something like 0x000000??. Its the last two digits that are the clue to why this is happening. Google the stop code and you will now know why this is happening and do something to stop the problem.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Feb 03, 2011 | Dell Dimension E310 PC Desktop
Hi, i have a dell inspiron 1420 laptop. i bought is 1 and half years ago. everything is going fine until i have the windows vista os on it but when i installed windows 7 some problems have...
First, the audio problem is related to your drivers, i would go to realtek and download realtek hd audio manager
and realtek ac97 audio drivers. Second, the power supply is what is causing the error, if you take the power supply in to best buy, they will replace it, sometuimes even for free, as this happens alot.
Dec 18, 2010 | Computers & Internet
Computer wont restart
try booting up in safe mode and run Disk Clean up, and run a Virus scan, and anti-spyware scan, update all system drivers. and scan for disk fragment faults
Jun 23, 2010 | Alcatel Speed Touch USB (3EC18607GA) Modem
I hit F1 key and screen is black...been in phone with Dell for over 45 minutes...help I am on another pc
when you hit F1 key it was on the Dell screen logo right? so after hitting the key F1 it just go straight black screen with a cursor?
since you where able to get display try. 1. turn off laptop make sure ac adapter is plug in. 2. while laptop is off press and hold on the Fn key then press power while pressing on Fn. 3. Check if a self-assessment will display and run on the screen. Just follow the prompt messages on the screen to guide you for the error messages which will help you to identify the problem.
Mar 27, 2010 | Dell Inspiron 1545 Notebook
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
Screen not working
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
Aug 07, 2009 | Toshiba Satellite L305-S5907 Laptop
Appear F1 to continue
becasue defaults bios settigns are loaded.
Wehn u power up press "del" key then u enter in bios setup
then press "F10" key then save settigns then exit
then it message not comes.
May 30, 2009 | Computers & Internet
Replace CMOS battery
First you need to take the cover off your laptop and locate the cmos battery which looks like an oversize battery watch. With everything unplugged it just pulls out, note which side of the battery goes however. Place the new one in put everything back together and power the computer up. When it powers up it will finally get to the screen that says press "F1" for setup or "F2" to continue. Press F1 and you will get to your set up screen. You can go through each screen and select F5 which is the default factory settings or scoll across the top to the last screen which will give you the option of resetting all the settings to factory default with just pressing one of the F keys once only. Once you do that, just shutdown your computer and restart and it will start as normal. It may go through the F1 and F2 screen one more time but just press F2 and continue. After you log off the next time all your changes should be good. Let me know if I can help you in any other way.
Jan 25, 2009 | NEC Versa VX Notebook
Computers & Internet Logo
199 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
