Zenith RZ46Z83D8(sm)projection TV. Cannot get the colors to converge. The red is arced from center to top left and will not move. Right now, the picture looks like 3D without the glasses
Suggestion:
Replace the television.
-Juice
Posted on Aug 07, 2008
Zenith pvr5263rk can not converge any colors through menu
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 23, 2010 | Zenith R49W36 49" Rear Projection HDTV
R56w36 convergence problem. color misaligned. Ghosts.
Dear Sir:
Thank you for contacting fixya.
Please follow the steps below.
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 10, 2008 | Zenith Televison & Video
The picture arced and looks 3D. Plus the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.http://www.ehow.com/how_2034880_perform-convergence--tv.html
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
Conversion-----the red lines are distorted so badly they won't move at all. I've managed to line the other lines up. The top left quadrant has drooped so badly that they will not adjust back. The bottom...
  • Screen looks 3D
Feb 11, 2010 | JVC AV-56WP74 56" Rear Projection...
The tv has shadow of red and green about 10 inches in on both left and Right sides. Center is still ok?
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Zenith D52WLCD 52" Rear Projection...
Double VIsion on Zenith R49W36
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 18, 2009 | Zenith R49W36 49" Rear Projection HDTV
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
  • Screen looks 3D
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
