Question about Neff Ovens
When not in use B1451 oven will suddenly start an intermittant droning/rasping noise and clock goes blank but small red lights above clock start to flash, turning it off at the switch for a while rectifies problem but happens again after a few days.
    Sergeant:
  • 228 Answers
Faulty power supply through clock either needs new clock or all clock connections checked for corrosion.
Posted on May 29, 2010
HOW DO YOU REMOVE CONTROL KNOBS TO REPLACE THE ON THE NEFF B1451 OVEN
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Jun 24, 2011 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1451 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1451 Single circotherm plus Electric...
Once the seletor is on fan there is no heat in the oven and i have already changed the element.Is it possibly a faulty selector switch.
It's possibly the switch, I would first check your connections to the new element, check there is continuity in the new element (just because it's new doesn't mean that it's not the problem). Check that the clock is set and not on auto. It could also be the oven stat, does the indicator light come on above the temp knob (if it does this is a good indication that there is power to the element).
Use the link, look at page 4, check there is continuity across part 057895 (next to fan). page 2 make a visual check of parts 167546 and 183598 for blows on the board or scorching on the switch.
Hope this helps and that it is something simple, best of luck.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=B1451W2GB%2f01&ESHOPTYPE=S
Aug 23, 2010 | Neff B1451 Single circotherm plus Electric...
Switch oven on and it fails to light and goes off again
gas man told us that the timer was not linked with oven and this was solved by correcting the clock
Sep 11, 2009 | New World G90m Gas Double Oven
Loud droning noise from fan.
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
May 27, 2009 | Ariston Technologies Ovens
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
U1721 Strange Problem
could be a clock fault - try bypassing the auto function on clock.
otherwise, check the terminal block where mains is connected. these quite commonly burn out
Jul 06, 2008 | Neff U1721 Double circotherm Electric Oven
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
117 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
