Question about Kenwood KDC-MP919 CD Player
NEED INPUT - Kenwood KDC-MP919 CD Player
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Http://inform3.kenwoodusa.com/manuals/kdcx859.pdf this is the website to look at the manual for this deck
Posted on May 09, 2010
Which input db to choose for mixer input in carlsbro amp powerline 2000 because there is 3 options +3db 0db -3db, i think 0db is high?
That will depend on what instrument you are planning to plug into it. Set the mains and the channel volume to a low-reasonable level and plug in a play. It the input is distorting, you need to use a lower input level. If it's too quiet, you need to use a higher input level.
Mar 24, 2016 | AMP Music
How do I change the settings on a Bravo 50" flat panel television which is set for Cable to receive an external signal from a separate DVD player: the cable connections (audio and video pin plugs) and
You just need to change the input of the tv to the input the DVR is on. If you are plugged into input 1 on the back of the TV then you need to switch your tv input to input one from your remote. The remote key you are looking for will be either "input" or "source".
Nov 13, 2014 | Televison & Video
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Our screen says video 1 with no picture
This is usually an easy fix. Depending how your tv is connected. Most probably it is the input you are on, or not on. Get your Sony remote look for a SOURCE or INPUT button. Press it and go to each input, for example, HDMI-1 2, INPUT-1,2 VID-1.2.etc.. Also check to see if your cables in the back is loose or out. Hope this helps
Aug 07, 2010 | Sony KP-51WS510 51" Rear Projection...
How to connect it to computer mic input
Instead of using the mic input on your soundcard try using the auxiliary input. You will need a cord that converts from 1/4" mono to 1/8" stereo. That cord goes from out on your pedal to aux in on your computer. Use whatever you need to go to the input of the pedal.
May 31, 2010 | Behringer Bdi21 Bass V Tone Modeling Pre...
From reciever output to sub input only load hum.but if connected to input does work some. also if you move around RCA input connection hum will stop, and you will get some bass
You have a RCA input short, replace with new monster RCA cables tighten any screws, unit would need internal soldering possibly. You may need to get Serviced or fix on your own.
Apr 08, 2010 | Audio Players & Recorders
I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
Feb 09, 2010 | Televison & Video
I cannot get the DVd to workthrough the TV
You need to select the correct input. Wherever you have the DVD cables hooked into, there should be a label saying INPUT 1, or INPUT 2, etc. Change your TVs input to match the DVDs input.
Apr 23, 2009 | Televison & Video
How can i connect an mp3 player on my Power Acoustik PTID-4007
Expandability Options:
  • 3 sets of preamp outputs (front, rear and subwoofer)
  • Telephone Mute trigger wire for Bluetooth adaptation
  • iPod Ready: IC-1 iPod Connection Cable Required and Sold Separately
  • Front-panel auxiliary input: Mini USB input and SD Card slot
  • Rear auxiliary input: 1 back-up camera input and 1 A/V input
  • 1 Video output
The aux rear a/v input should do the trick.
If it is a component (RCA) type input, you will need a Male 3.5mm to dual Male RCA adapter.
If it is a 3.5mm input, a Male 3.5mm on each end.
I believe you will need the Dual RCA (red/wht) to 3.5mm cable.
The Audio inputs are purple RCAs on the back of your head unit.
Jan 14, 2009 | Car Audio & Video
Video input 4
If you changed PIP then you reversed your tuner, you need to flip back and is input 4 HD on this set? Or S-Video or just another component video? What is wrong with 3-1?
Sep 21, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Kenwood KDC-MP919 CD Player Logo
47 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
