Question about Safe International Locks & Locksmithing
PROBLEM WITH electronic safe 20ea.
I have safewell electronic safe 20ea. When I entered the code the safe couldn't open, the batteries are OK. And also I have tried with the safe's own key, but key doesn't work, I think it's stripping. How can I solve this problem? I need your urgent help
  • 124 Answers
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Posted on Sep 14, 2009
SOURCE: i have a safewell electronic safe and no keys and
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Posted on Sep 02, 2009
  • 905 Answers
SOURCE: Hi there, I recently purchased a
The keyhole for the emergency key is likely located under the plastic label to the right of the knob. You will need to insert the key, turn it, and then turn the knob to withdraw the pins and the door should then open.
There are a few version of this safe that are floating about, they were made for several different companies. The exact version that you have is unknown, but the key hole is likely hidden behind a label, or could be under the knob itself (although unlikely since you have to be able to turn the knob while the key is turned as well).
Posted on Aug 18, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a Safewell Electronic
won't work.
ELECTRONIC SAFES
electronic keypad -159B. (These numbers are preset. You should change the code as soon
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Good luck
Posted on Nov 30, 2010
just **** a ****
Posted on Apr 06, 2011
Safewell EX2005327788
A set of emergency keys is supplied with every Safewell safe. In case the batteries drain out, you may use the emergency key to open the safe. These keys override the digital password. Remember, never keep the emergency keys inside the safe.
Jan 14, 2015 | Home Security
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
won't work.
ELECTRONIC SAFES
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
knob so you can turn it and retract the locking bolts.
Apr 22, 2014 | Computers & Internet
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
I have a safewell electronic system EX2005156761 without keys and the batteries run out. How can I open it?
Without having to drill it out, it is possible for a locksmith to impression a key for the safe. Another possibility is contact the manufacturer, give them the model and serial number AND show proof of ownership. They MAY be able to send you a replacement key.
Jan 26, 2011 | Safe International Digital Electronic Safe...
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
Safe won't accept the code and the keys are lost
Without the keys and safe code you will need to call a locksmith. Even then they might be skeptical about opening the safe for you. There should not be any "backdoor" way of opening the safe for security reasons otherwise it defeats the reason for having the safe. I would contact the safe manufacturer for further instructions or you will need to cut open the safe if the locksmith and manufacturer cannot help you.
Sep 23, 2009 | Locks & Locksmithing
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
Good luck
Sep 14, 2009 | Locks & Locksmithing
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
Jul 26, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
724 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
