Question about Honeywell Heating & Cooling
PURGE LIGHT FLASHING
Cold air blows for about ten minutes then it stops. I have a honeywell minizone controller. the panel says when the purge light is flashing that the ZMS sensor is bad what is that and where would I find this sensor so I can replace it???
  • 674 Answers
It is a discharge temperature sensor and should be located in the duct after the coil. It should be just before the bypass damper.
Posted on May 09, 2010
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
How do i reset a zone circuit breaker in an hz432 control panel
remove cover and look for a micro switch labeled purge press and hold for three seconds all zones will reset all dampers will open equipment fan will run for up to five minutes and a yellow lite will flash
May 31, 2014 | Honeywell Truezone HZ432 Zone Control...
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
2004 Chrysler Pacifica a/c doesn't blow any air in front vents, only defrost works
I have the same problem starting on mine. The first answer above is totally wrong. The actuators that control the doors are 12 volt electric no vacuum. There are three actuators on the drivers side under the panel by the gas pedal. I haven't worked on mine so I can't tell you which one it is but all are the same part and interchangeable take a new one and try it in each position until it works.There is one in the center console and one under the passenger side by the blower motor the console is for rear HVAC and the passenger one is for recirculation after installation it will have to be calibrated . Turn ignition to ON not start push the power button and the recirculation button at the same time hold for 5 seconds lights should start flashing leave it for two minutes or the lights stop flashing. If they don't stop recalibrate until they do. If they won't stop drive for eight miles and it will stop on it own. (but not fixed)
Jul 09, 2012 | 2004 Chrysler Pacifica
My 1995 subaru legacy lsi cuts out when I rev the engine around 1 rpm. Plus the check engine light is on. I took it to the dealership and they couldn't fix it, but they got a code from the check engine...
code p 0441 refers to evaporative emission (EVAP) system --incorrect flow detected ==== causes --- hose connection/s--- intake leak---EVAP canister purge valve replace the purge valve
May 21, 2017 | 1995 Subaru Legacy
Heat not woking purge light flashing
The flashing light is giving you a code as to what is work... have you tried to recycle the power???
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jan 15, 2011 | Honeywell Electronic Programmable...
Honeywell fx4bnf048 Yellow purge light is flashing slowly. Instructions say sensor failure or sensor not installed...
i have honeywell system and zone 3 is off and purge light flashing and i have heat in all rooms except for my daughters room??? please HELP
Sep 22, 2010 | Heating & Cooling
I have a Lennox A/C and air handler with a honeywell thermostat and the purge light is blinking. What can I do? I am not getting cold air.
check with thermostat commands from indoor to outdoor.May be your outdoor unit doesn't have command to operate.
Jul 24, 2010 | Amana PTH123B35AE Air Conditioner
Purge hotwater heater gas line of air
Hi, What you have to do here, is to take the flex line loose at the flare connection at the hot water control after shutting off the valve 1st. When this is done, open the valve for a few seconds to purge the line of any air that may have been trapped. Re- connect the line and turn the knob to pilot and hold it down until you can smell the gas or hear it. Wait a few minutes and hold it down again and you should have no problems lighting it. If it continues not to light, there may be something in the pilot line at the end of it, and you may have to remove the assembly to clean it out. Very easy to do. Just remove the gas flex at the control, and maybe the nipple that the flex screwed to. The control, pilot and thermocouple will all slide out together along with the burner. If there is a spider web inside donot blow it as it will not blow out. You will need to run a peice of a metal coat hanger or stiff wire through it. Replace it in reverse of taking it out. You will have to purge the air out all over again. Please keep me posted as I know you can do this. I have confidence in you.
Sincerely,
Shastalaker7
Jan 23, 2010 | Honeywell Heating & Cooling
2004 toyota celica will not blow hot air for twenty minutes
If the engine temprature does not reach the normal level as it used to, it may be the coolant thermostat.
Iif it does, it could be air diverter gates not working properly, cold air blowing at a a light could point to that. The diverter gates are located under the dash.
It also coul be the valuve that controls the water to the heater core, but unlikely cause of the cold air at a light.
Jan 11, 2010 | 2000 Toyota Celica
Heating & Cooling Logo
1,126 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
