Question about Vizio VO47L 47 in. LCD TV
I want to configure my direct tv remote (hughes) to turn on my vizio tv. I can't find vizio as an option in the menu for set up. I also need a 3 digit code for vizio, however I only find 4 digit. how do i get the hughes box to sync with my vizio tv to use only the one remote control?
  • 8,197 Answers
Actuly you can get the remote to work with your TV. I also have direct tv and a vizio and my direct tv remote works the tv. I need to get you remote model # to be able to help you program the remote. Once I have that I will give you the instructions on how to program it. Please add a commet when You can provide it to me.
Thank You
Posted on May 09, 2010
  • Jyackle5
    Jyackle5 May 09, 2010
    May I get the remote model # to help you or you can call direct tv at 1800 directtv they will walk you throught the setup.
  • brigitte eglevsky
    brigitte eglevsky May 10, 2014
    RCRN03BR Universal Remote for a Vizio E241I-A1 Smart TV
  • Vizio Master
  • 3,866 Answers
Not all dirct tv boxes are comptable with all TV IR fucntions Thus you cannot find it on the list nor any genric off code will work. However! a solution is aviable for a 1 remote idea. That is called logictech harmony remote witch is programmeable and recives updates. Other then that the issue here is clear that its not working nor its on the list.
thanks please do leave some feedback and ratings for your free answer today.
Posted on May 08, 2010
I had my direct tv disconnected and now I can not get the tv to respond to the reg. visio remate
Hi, In the direct tv settings you have to set it back to the vizio, direct TV builds in this remote programming feature, of course the TV needs to be on showing the direct TV menu first,
Aug 13, 2014 | Vizio L32 32 in. LCD HDTV
Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
Nov 25, 2007 | Sylvania SH50102 LCD Remote Control
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
Have a vizio tv and an input locked messages appeared and turned the tv off . Now when you turn the tv on the tv shuts off. How can we fix this? We unplugged the tv and pressed the side . We plugged the...
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the side of the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV
6- Power the TV back on
Apr 27, 2011 | Vizio M370VT 37 in. LCD TV
42 inch vizio has picture (direct tv) but no sound. Tv is not on mute.
Did you check the RCA AV Cables? The ones with the red, white yellow?
What is the connection you have from Direct TV box to your TV. You might want to start on that.
It might probably as well related to any of the remote controls settings. Either of the Direct TV control or TV Control.
1. Check the cables
2. Check if there is any function on the Direct TV remote that will turn off the sound
3. CHeck the Vizio TV Menu Settings.
4. Try with other component such as DVD to discard the possibility of malfunctioning VIZIO Speakers.
Vizio offer a good customer service if still under warranty.
God Bless You!!
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Dec 19, 2009 | Vizio SV470XVT 47 in. LCD TV
Lost the Hughes manual. I need the code settings for the remote
Here are two links for the manual you are in need of:
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
http://www.solidsignal.com/manuals/HRMC-11_HRMC-12_Owners_Manual.pdf
Either of theses should get you to the correct manual and should have the code you need.
Feb 27, 2009 | Hughes HRMC11 Remote Control
I've just bought a 26" VIZIO LCD HDtv and I need the code
Try one of these:
Vizio 10864, 10885, 11756, 10178
Feb 01, 2008 | Hughes HRMC11 Remote Control
Picture sometimes goes to zoom mode when changing satellite channels
TV should still be in warraty, if this needs to be fixed, you should be able to get it repaired/replaced for free from the manufacturer
Oct 20, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Vizio VO47L 47 in. LCD TV Logo
640 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
