Question about Drills
Drill bit keeps coming loose - Drills
  • 10,865 Answers
When the drill bit on a hammer drill keeps loosening up one of two things is happening. 1. The chuck is worn out and needs to be replaced. 2. The chuck is not tight enough before you start drilling. If you have the style of chuck that requires a key do not be bashful about using maximum force to tighten the chuck and move the chuck key from hole to hole and tighten it in each position. Joe
Posted on May 08, 2010
Why does my chuck keep loosening
First check whether you have the correct transmission setting for the bit you are using. This may affect the range over which the chuck operates and how it locks onto the bit. A conventional small-diameter drill bit may not work with a hammer drill setting. If the setting is correct, then either your hands aren't as strong as they used to be and you're not getting the chuck tight, or the chuck is worn and no longer has enough friction to hold.
Try this diagnostic: when you put a bit in, use a fine-tip felt marker to draw a line from the chuck collar (the part you turn to tighten or loosen) to the chuck baseplate. If the bit comes loose, check to see if the collar is still lined up at the same place relative to the baseplate. If it is, the chuck pieces are slipping inside; perhaps the transmission setting is incorrect for the bit chosen. If the collar has worked loose (the marks didn't stay lined up), the threading on the collar or the parts it engages could be worn.
May 23, 2014 | Dewalt 18v Battery Hammer Drill Dcd950...
Ryobi 18v Lithium cordless impact drill chuck comes loose while drilling
Tighten the screw inside were the drill bits or attachments go this is a reverse threaded screw try using lock tight also
Aug 31, 2013 | Ryobi 18v Variable Speed Impact Driver...
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
Jan 13, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
A dewalt dcd970 18v xrp and when i try to unscrew anything the bit comes loose. Can't figure out why?
check the inside of the chuck at the bottom(open the chuck to max). There should be small screw there with either a hex or a Phillips head. It is a left hand screw that locks the chuck in place and will not let it unscrew when you are removing parts.. If it is not there then you will have to get one from an old drill that is junk unless you can get one from an electrical appliance shop the repairs drills.
Oct 24, 2011 | Dewalt Air Tools & Compressors
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Oct 04, 2010 | Black & Decker Pivot Plus Cordless...
DeWalt cordless drill DW926. I can't get the
Turn your drill speed selector to "1" and put drill direction in reverse. Hold the outer end of the chuck and push the trigger. Should come loose.
Nov 18, 2009 | Dewalt Cordless drill/driver kit 9.6 volt...
My new bits 22mm and below keep jamming and burning the wood
All new bits come with a 'dressing' to stop corrosion. To remove it, spray with releasing oil ( wd40 or sim) and leave for about an hour. Wipe clean with a lint free cloth. This will also protect your bits from becoming rusted in the future. If you are drilling high grain woods like oak or beech, which are very hard, don't push the drill bit in, let the drill do it's work and just drill slowly, the harder you push, the more friction will created. Regards, dave.
Aug 11, 2009 | Drills
Keyless chuck will not tighten down enough to hold bit
What size bit are you using if it is real small it may be below the min sixe require for that chuck .If it is say 1/8 or larger it may be time for a new chuck .They are easy to replace open the chuck as far as you can there is a screw inside them most of them are left hand threads just back it out and tap the chuck loose with a hammer .Make sure you know the threads of your chuck when you buy the new one most are 1/2-20 but some can be 3/8-24 tpi
Nov 18, 2008 | Black & Decker HPD18K - 2 High Performance...
Drills Logo
1,666 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
