Question about NTL VS2000 Cordless Phone
Lost instructions ..how do i listen to answer phone messages?
  • 343 Answers
Http://rwec.co.uk/ntl-vs1500/
read first
Posted on May 08, 2010
rizla
  • 1463 Answers
SOURCE: how to set message for answering machine lost directions
hi is this your phone here http://evaluezone.com/dxi986-2.html
also you can get the manual from here as well .
or a search on there web site Uniden | A World Without Wires
may find the right manual .
riz.
Posted on Nov 19, 2007
cindystauart
SOURCE: How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Posted on May 12, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
  • 15 Answers
SOURCE: answer phone
You can download the User Manual for the VS2000 at:
www.cordless-phones.uk.com/userguide/vs2000.pdf
Hope the solution is in there!
Posted on Mar 01, 2009
saailer
  • 1868 Answers
SOURCE: i have lost instruction manual for binatone fusion
Hello! Go to; www.binatone.com.au/pdf/2510manual.pdf
Guru.................saailer
Posted on Jan 08, 2010
How can I get my Uniden Answering Machine Dect 6.0 to get messages?
You may be subscribed to a voicemail system provided by your telephone company. Please contact them for instructions on accessing their voicemail system.
May 04, 2012 | Uniden DECT 6.0 Cordless Phone ID
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Retrieve voice messages remotely
Remote operation instructions begin on page 62 of this manual.
Jan 05, 2009 | Uniden TRU8885 Digital Answering Machine
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Philips CD135 Twin cordless
press bottom left button and then hold down 7. display will show 0-0 to indicate its turned on. 2 to read messages. 3 to skip to next messge. 4 to record your message. 5 to listen to current welcome message. 6 to delete messages. 7 to activate answer machine. 9 to deactivate ans mach. 0 to record internal memo. To use any of these functions bottom left button must be pressed first.
Apr 07, 2008 | Philips 2252 Twin Cordless Phone
Uniden telephone answering machine
Replaced my battery for my Uniden 900MHz phone and lost my instruction book..Need to program it again for memory numbers.
How do I do that?
Feb 23, 2008 | Uniden Cordless phone EXS9950
Panasonic phone KX-TGA109EX
to access the answer machine press the top left hand button until a swirly thing flashes then press 5 to listen to your messages, then press the hash button to remove the message.
To lock and unlock the keypab also press the hash key. It has a key symbol on it.
Feb 02, 2008 | Lands Phones
How do you retrieve messages from another phone?
If you have not changed the code, it should be set to the default code 1-2-3. Call the phone with the answering machine, and as soon as your greeting starts press 123. You will then hear a menu. Press 1 to retrieve your messages. After listening to your messages, you can listen to the menu again, which will tell you that you can press 0 to delete your messages, among other choices. Cathy
Jul 15, 2007 | GE 29871GE3 Digital Answering Machine
NTL VS2000 Cordless Phone Logo
115 people viewed this question
Top NTL Lands Phones Experts
Computer Repairing
Computer Repairing
Cliff
ray gallant
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
