Question about Canon EOS 400D / Rebel XTi Digital Camera
Canon 400d self cleaning sensor doesn't work anymore. At first I couldn't turn off the camera, now de cleaningsensor doesn 't work properly. Can anybody help me out?
  • 94 Answers
Camera self sensor cleaning board is faulty or check connections is good between sensor and self sensor cleaning board,
other wise you need te replace that active sweep board
Posted on Aug 08, 2010
    Problem Solver:
  • 7 Answers
Look in your settings make sure that you did not accidentally turn it off.
Posted on May 09, 2010
4 Suggested Answers
poolseman
  • 206 Answers
SOURCE: Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Posted on Sep 10, 2007
SOURCE: Canon EOS 400D
The camera is working again. I took out the battery, with the the on/off switch, off. I then swtiched the On/Off switch On. I then put the battery in ,and the camera turned on.It then gave me an ERROR 99. I then switch it off and on again, and it is still working.
Posted on Apr 29, 2008
MrsJGreen
  • 130 Answers
SOURCE: Canon EOS 400D LCD screen problem
There is no live preview mode on this camera. I am not sure if that is what you are referring to, but you can only use LCD for review and menu, not as a viewfinder.
The new Rebel XSi is the only one in the rebel series with this new feature.
Hope this helps!
Posted on May 30, 2008
Mijn Canon 400D geeft error 99 en 9, wat te doen
This error message is common to a broken lens ribbon problem. Does the lens work in manual and not in auto. If so it could well be the problem. The fix is to have the lens ribbon replaced.
Jan 25, 2016 | Canon EOS 400D Digital Camera
How can i switch video mode in canon 400d, 10 mpxl?
Use the "Video system" command in the Setup-2 menu to switch the video output between NTSC and PAL. This is for playing back your still photos on a TV.
If you're asking how to switch the 400D into video recording mode, the 400D doesn't record video. Sorry if that wasn't the answer you wanted to see, but that's the way it is.
Jul 31, 2012 | Canon Rebel XTi / EOS 400D (body only)...
Computer does not recognize my canon eos rebel xti 400D
You can download the driver aand reinstall it from this link: http://www.nodevice.com/driver/EOS_400D/get37008.html Make sure your existing Canon software, if any, is removed before installing the new driver. If this doesn't work you can always purchase a card reader and extract your photos directly from the memory card.
Sep 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon 400D camera keeps coming up with error 99 I have cleaned the contacts on both my camera and my Tamron 28-200 lens.At first i thought it was my camera but I tried it with another lens and it...
Hi turn on the camera with the lens on set to tv and a iris of f22 and use the stopdown button if the lens stops down the lens is ok if not the lens is faulty may need a intuper replaced
Jan 11, 2010 | Tamron 28-200mm F3.8-5.6 for EOS
I have a Canon EOS 400D. Photographs are appearing with what looks like round marks or bubbles in the image. I've cleaned and changed the lenses but it still appears. I am wary about cleaning inside the...
There is a mode in which you can lock up the mirror and shutter blades so that the sensor is exposed. Use a appropriate cleaning kit and avoid touching the sensor.
Jan 01, 2010 | Canon EOS 400D Digital Camera
Need Help, the auto focus of my canon 400D won't work.(I can still shot with manual focus)
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
My 400D won't turn on
Did you overtighten the tripod screw?
Aug 16, 2009 | Canon EOS 400D Digital Camera
Turning on infared on my Canon EOS 400d DSLR
To the right of the LCD there are some small buttons. Right underneath the AV button, there's one. Press it, and you get three choices. The right most choice is self timer and wireless. Choose that option. The remote needs to be pointed towards the eye on the camera. It's on the front, on the "motor grip". And if you leave it on that setting too long, it "falls asleep", and you have to wake it up again before it'll fire remotely.
Mar 28, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
F stop
Sounds like your camera and your lens aren't communicating. Have you tried cleaning the contacts on the camera and the lens mount?
Sep 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
