Question about Refrigerators
The top part of my fridge does not work have replaced the control card and transformer but still its not cooling the interior light and blower are not coming on
  • 4 more comments
  • tonano May 08, 2010
    My Top part of the fridge is not working the interior light and blower are not coming on despite changing the control card and transformer and the door open control buzzer does not stop buzzing
    Have Checked all the same and still not working any more solutions
    My top part of my fridge freezer is not working despite changing the control card and transformer
  • tonano May 09, 2010
    Any idea as to how to rectify the wiring system?
  • tonano May 10, 2010
    Thank you for your assistance but I found the problem was with the Light control switch for the top part of the fridge which also controls the fan blower as such because it was not working the card was getting a signal that the door was permanently open so the blower was not coming on I hope this info will be of assistance to you in the future.
    Morning Thanks for your tips have managed to find the problem, It was the light control switch for the top door of the fridge which also controls the blower since it was not working the card was getting a signal that the door was permanently open thereby not engaging the blower.Hope this info will be of assistance to you in the future.
    Tonano.
  • Refrigerators Master
  • 19,396 Answers
Hi.
The symptoms let think that there is a wiring problem, or that the damper fan motor is faulty.
To start ensure that there is no problem with the defrost system. A way of testing the defrost system is by leaving the unit disconnected from power for 24 hours, allowing full defrost.
If the unit is cooling regularly after defrost, that means that defrost system is malfunctioning or that damper fan was blocked by ice.
If that does not work, then the problem can be a faulty damper fan, or a wiring problem.
In fact, if defrost system was not causing the problem, then the fridge will still display the same problem after complete defrost. In that case check damper motor and temperature control.
The fan can be tested by a technician jumping its contacts to energize the motor directly. Wiring is tested checking continuity between different points of the harness.
See here how to locate parts and diagrams: Where do I find parts and diagrams?
To contact an authorized technician or to check warranty status call the manufacturer at the number listed on the owner manual.
Regards.
Ginko.
Posted on May 10, 2010
    President:
  • 2,468 Answers
Have you checked the damper vent door to make sure its opening fully,its located between the fridge and freezer inside a plastic grille,they can freeze in a position and not throttle in cold air,also is the compressor cycling often,if so check the ptc overload relay on the compressor for being weak,and finally the cold control could be defective and shutting off the unit before its cold
Posted on May 09, 2010
  • 952 Answers
Thanks for using FixYa.
If the blower doesn't come on, the upper part of the fridge will definitely not cool down. There is probably something wrong with the wiring system thus affecting the interior light and blower. The problem is with the wires itself, not the control board.
I hope this helps. Thanks and good day.
HotRatchet
Posted on May 08, 2010
  • 1,284 Answers
Hi, Almost always, your described problem indicates that the fan/blower is not drawing cold air from the freezer section towards the refrigerator section. This could be a faulty fan or the air passage is blocked. In some instances, this cold be the thermostat of the refrigerator section but offhand this would be least likely.
A possible way of testing is to open the fridge door, locate the door switch and press on it while the door is open. The interior light should turn off. After some time, the fan should kicked in. Should it not, then possibilities are:
  • faulty fan (most likely);
  • blocked air passage (likely);
  • thermostat (least likely);
  • faulty fan controller (a possibility).
Take care
  • 1 more comment
  • Shehu Pro
    Shehu Pro May 08, 2010
    Have you checked the compressor and relay switch?
  • Shehu Pro
    Shehu Pro May 10, 2010
    Hi, thanks for the info to......
  • Shehu Pro
    Shehu Pro May 16, 2010
    O.k....
    President:
  • 2,923 Answers
Check to see if the thermostat is set properly. If both of these are OK, then check to see if the compressor is running.
See if the compressor motor is running. The compressor is in a case with no visible moving parts. It is usually located at the back of the refrigerator near the bottom. If it’s humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components.
Refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8’s of a turn. If the compressor starts, replace the defrost timer. For further help, you’ll want to call a professional appliance repair technician.
Sometimes you can hear a click-buzz-click sound coming from the compressor. This is the relay/overload at work. If you hear this, power is getting to the compressor. If you do, something is wrong with either the compressor or the compressor starting components. If you have a newer model with solid-state starting components, you may not hear anything at all. If there is power to the starting components, you may be able to test each part and replace any bad parts.
There is also a 3-in-1 unit that may work on your model which replaces all the components in one unit. If the compressor still won’t start, you have a bad compressor and need to replace it. If it does start, wire the 3-in-1 part in permanently. Make sure the one you buy is rated for the horsepower of your appliance.
If you don’t hear anything, you can take the cover off the side of the compressor and test for voltage at the two leads. If no voltage is present, it’s time to check the cold control. To test if the cold control is bad, you can temporarily jump the two wires at the cold control. If you get power to the compressor after doing so, the cold control needs to be replaced.
Thank you and good luck!
I have a double door Whirlpool refrigerator #ED26MMXRNRA. The interior lights come on but there is no cooling. i exposed the control panel at the top of the box and checked that there is no current to the...
It can be the thermostat controlling the refrigerator telling the when to cool and not as to keep at constant temperature. It is located inside the refrigeration part of the fridge behind the panel. It is a small round object normally pricing around R250.
Sep 11, 2013 | Whirlpool Refrigerators
We have a side-by-side kitchenaid refrigerator (Model KSSC48QMS01) and the sides are heating up. We had a technician check the voltage and control board: The technician indicated that there seems to...
Interior cloth art
Interior cloth art estimation is among the most women like owners, in the seat you want a mix of the headrest, in instrument desk or rail box on put a fuzzy is embroidered with lovely image paper towel box... Interior cloth art product mainly to car pillow, strength pillow, headrest, face towel box, cell phone set content box and various accessories primarily, by fashion, innovative, progressive, colour diversity is characteristic. The items is usually put into: business series, leisure series, cartoon series, etc, as a way to meet the requirements of various owners. Products in with makings fastidious, embroidery elegant, quality of an material is extremely good, the planning is lovely and owner like.
Interior toys
Now get around auto supplies market, greatly small high-quality goods produce a person dazzling, one kind of solar doll let anyone fondle admiringly. Modelling are: with earplugs little XiongHuang his head to focus on music, lovestruck QQ doll image kiss each other, green small seedling two leaf there fan ah fan... Get a assumed the automobile, that is so conspicuous, lovely. Along with these solar doll outside, and glued towards instrument desk spring toys, from the rear of the car seats or around the cotton material figures, etc. Stop expecting or traffic annoyed, examine these small toys, the climate is going to be relaxed many. Is decorated online resources the vehicle, but also decorated the owner's dream.
Aug 21, 2012 | KitchenAid Refrigerators
Carrier Furnace LED Good, Blower does not kick on
Likely a variable speed blower. Very common to not get 24 to the blower. Carrier is notorious for bad blowers, double check for 240, don't believe it has a separate module, but that's probably all it is. Likely have to replace entire motor. Good Luck
Mar 20, 2017 | Heating & Cooling
Power on Interior lights on refrigerator does not operate not cool
The interior lamps fail to light up as the swittch is faulty , so replace teh door switch if a contact cleaning wont help.
Now the cooling is related to many issues, so shut off fridge to allow time of 5 hours, The restart , if the fridge does not cool , the compressor , gas pressure is done and must be checked. If cooling is present then check if the auto defrost timer/thermostat is faulty as the fridge might stop cooling after 12 hours.
Sep 29, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Blower only works on 4 (top speed)
sounds like you need the blower speed resistor...once you put in the new one it will work just fine.......
Sep 19, 2009 | 2000 Ford Focus
Blown Transformer heat pump
blown transformers are usually from a low voltage short the first thing i would do is wire a automotive or resetable 3amp fuse in line with the transformer so you dont blow transformer after transformer the wire coming off the transformer that say 24v take that wire a couple of inches down and cut it and install the fuse in series there
24v----------------
24v----------x----------
24v--------{3ampfuse}----------
now you can go through your low voltage wires one by one and test them unhook all the wires to your outdoor condenser at your indoor unit(furnace or airhandler) and try turning it to cool now if you blow the fuse the short is between the tstat and the indoor unit if the fuse is still good leave it on cool and hook up one wire at a time to your outdoor unit starting with R a lot of times your contactor or your defrost board will short out on you also look for pinches in wires wires with cracks in the insulation and wires touching metal this situation can be a real pain sometimes i would recommend calling a hvac company if you start to get stumped
hope this will help you
Jul 26, 2009 | Ruud UBHC Air Conditioner
Fridge not cold at all.
check the adaptive deffrost control inside of the refrigerator compartment, more than likely thats bad.
Apr 05, 2009 | Freezers
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
