Question about Troy-Bilt Pony Garden Tiller
Need to put on the belt
Need the manual to put on the belt
I need a diagram of a serpitine belt on a 1998 cavalier and will I need to remove any bolts to release it or put on.
You should have a diagram of the belt installation on the radiator support, usually a sticker.
I found your owners manual online but there is no reference to the belt. You may have to buy a Chiilton's or like manual from Orielly's or Autozone to get the pattern. Most serpentine belts use a tensioner and it
has a big bolt in the middle of it that you can put a wrench on and pry it to the side that makes the tensioner loosen off the belt and then slide the belt off the tensioner or other easy to reach pulley. You should nbot have to remove any bolts. That was the whole idea of the sepentine. A tensioner to keep it tight and easy removal and replacement.
Here is the site for the manual.
http://www.extendedgmwarranty.com/owners-manual/chevrolet/1998-Chevrolet-Cavalier.pdf
Mar 10, 2011 | 1998 Chevrolet Cavalier
I need to put a new belt so the water pump can work. do i have to take everything apart? how you pull out the pulley so you can put a new one? cadillac el dorado 1995
Sounds like you have the Northstar engine yes?...if so...you won't need to dismantle anything other than the water pump belt cover. You can then put the new belt on by levering the small belt tensioner.
Pulley's do not need to be removed, simply position the belt around the three pulley's.
Jan 01, 2010 | 1995 Cadillac Eldorado
Rollers don't turn and pump doesn't put out any shampoo or rinse water
You need to replace the Pump belt and the roller brush belt. You can get both belts and view the manual which has instructions here:
Bissell Proheat Replacement Belts and Manual
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need a manual so i can put my timing belt back
good day Sir, try this link i hope this will help you
lancer
Sep 17, 2009 | 2003 Mitsubishi Lancer
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
ALTERNATOR BELT
can be done manually, and go to autozone.com you might find some information for the belt
May 27, 2008 | 1988 Ford Taurus
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Troy-Bilt Pony Garden Tiller Logo
19 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
