Question about Polaroid FLM-3701 Television
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
Where is the fuse in a 3701 LCD Polaroid - f0aca626-8c0e-4fbe-adec-105f02f6518b.jpg
Posted on Oct 14, 2015
  • 43 Answers
Could be near the ac inlet
Posted on Aug 16, 2010
Polaroid LCD
It looks like your power supply might not be providing enough current to get the LCD to power up. This LCD needs about 3 to 4 amps to work properly.
Apr 12, 2008 | Polaroid FLM-3701 Television
Diagram where fuse is in the polaroid flm-3701
There is a fuse on the power supply board. It is labelled F1. It is a small cylinder near the AC connector. The F1 fuse is 5A 250V. How ever, capacitors are more likely to fail on this television.
The Polaroid FLM3701 has a problem with capacitors failing on the power supply board. If enough caps go bad, you will get no power. Not even a power light. Any capacitor that is swollen is bad.
May 12, 2014 | Polaroid FLM-3701 Television
Polaroid FLM-3701 power
Unfortunately modern televisions and monitors are full of electronic semiconductors of which many are likely have got destroyed along with your original power supply during the storm. A nearby lightning strike will send high voltage spikes down aerial cables as well as through socket outlets.
If you have contents insurance you should be able to claim for a new monitor.
Nov 09, 2013 | Polaroid FLM-3701 Television
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Is there a coaxial input on this tv?
No because it is a monitor only; meaning it does not have a TV tuner of its own.
Sep 23, 2012 | Polaroid FLM-3701 Television
No power
Connect the TV to some other power outlet and see. If problem persists, please refer it to a qualified service technician, as either some fuse is blown or some components in the boards have failed.
Aug 05, 2012 | Polaroid FLM-3701 Television
I've got a Polaroid FLM-3701 LCD TV. I have had the TV over 4 years and it's worked great. Recently it's starting to shut itself off. I say "shut off", actually the picture goes off, the power...
It may have dying power supply due to bad caps, this is common problem with 3+years TV and monitors.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 17, 2010 | Polaroid FLM-3701 Television
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
Televison & Video Logo
423 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
