Question about Kenmore 57029 Side by Side Refrigerator
Why did my ice maker suddenly stop working?
This is a Kenmore Elite side-by-side, made in 1/03. The water and ice discharge are in the door. The water is still discharging but the ice maker has stopped producing. The "Ice Maker Control" panel is showing a blinking red light. I have cleaned the ice from the ice chopper (?) gears on the bucket and the seat. Any help would be greatly appreciated.
ngfam1
  • 639 Answers
SOURCE: ICE MAKER ON KENMORES ELITE SS
Friend,
ngfam1 At your service!
You need service this time !
Sounds like a Thermostat problem!
How old is the ice maker?
If is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
larryyb
  • 291 Answers
SOURCE: Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Posted on Nov 26, 2008
SOURCE: Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Posted on Jan 27, 2009
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Posted on Apr 16, 2009
Ice maker stopped working suddenly. model no 106.56646500. Water is getting to the door but not coming out of the tube to the ice maker.
If you are sure the tube is not frozen the replace water valve. Also put 120v to the freezer water valve side to so if water goes up to the ice maker.
Mar 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker doesn't work.
TROUBLESHOOT THE ICEMAKER ON THE 54606300 SIDE BY SIDE REFRIGERATOR
May 02, 2009 | Kenmore 54603 / 54606 Side by Side...
Nov 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Problem with ice maker
With your limited input , all I can do is suggest some things for you to try..
First off, are you sure you have water coming to the back of the fridge? No water, no ice. Secondly, Can you gain access to the ice tray inside the ice maker to see if it is frozen with excess water ? If it is, you may need to thaw it out to free it up to allow it to cycle. If no ice buildup is found....
Can you tell if the icemaker is actually cycling? If you listen, you can here the inlet valve open to let water in and then you should hear the motor that rotates the mold tray operate ( may take between 10 - 20 minutes so be patient) If you don't hear any motor activity duing this time.... You may have a defectice ice maker assembly and may need to replace it. Hope that helps...
Aug 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
