Question about Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E monitor looses power at irregular times
My polyview V17E monitor looses power on a regular basis. Sometimes after a few minutes or sometimes will go for days with no trouble. The power lights on the tower stays on. Removing power cables from monitor and reconnecting has no effect.The only way to get the monitor back on is to turn power off to tower and then restart tower . Any suggestions ?
  • 51 Answers
Check your power saver settings
Start - Control Panel - Power
Posted on May 08, 2010
When i start up my computer the screen is blank - its a polyview v17e. we manually must press menu on the monitor then move across to display settings and select analog - the screen then starts up? how do...
You may have to look at the setup menu to see if you can turn on 'AUTO SOURCE SELECT' and set to auto. You may have problem with the logic board that is why it cannot auto detect the DVI or VGA port automatically.
Mar 21, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Jan 27, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview v17e - microphone?
G'day Matt,
No microphone. It has a line in socket to drive the stereo speakers.
cheers,
dave.
Jul 03, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
I have problems with my LCD polyview
These monitors are plug and play compliant and should not require any drivers. If you are having video problems it may be the video card.
Apr 06, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E
Same as before this sounds very similar to the problem that I had with my polyview v396 19" . Its a power supply problem unclip the panel withdraw the power supply it plugs in on its own seperate board. Look for capacitors that bulge and replace them in fact replace them all on tha board not that hard. Replace them with the same rating voltage and micro fards. Cheaper than relacing the whole panel, hope this helps. :)
Dec 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Driver for Polyview V17E 17" LCD Flat Pane
if you are using windows and it just won't let you go on the other resolutions try checking the monitor settings in your control panel
Nov 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
No sound
if your monitor has speakers, and it should  built in; then you will see a separate lead with  green plug on the end of it which is to be located in the rear of your pc with the green marked socket.
If theres no lead, then there must be a connector on the rear of the monitor
Oct 22, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Like most of these LCD monitors it is more than likely a PSU problem to do with the Electrolytic Capacitors, These in all probability will be faulty.. there are usually about 4 - 6 from 1000uF to 100uF replace ALL with same or better.
May 31, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E 17" LCD Flat Panel Monitor Logo
122 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
