HELP i went to do a load of laundry and put the cicle on normal. i went to change the loads over and my washer wasn't spinning, and i had a washer full of water and wet clothes. HELP what do i do...... is my washer garbage now or can that be fixed by the handy man of the house????
  • Jenbriffett Mar 27, 2008
    its not the lid switch.. that is workin properly.. When it goes to the drain and spin cycle it makes a little clicking noise then it just shuts off! it's not draining and its not spinning
SOME WASHERS ARE WIRED TO AGITATE AND ADVANCE WITH THE LID SWITCH ACTIVATED. SOME STOP EVERYTHING WHEN THE LID IS UP. IF YOU HAVE A BAD LID SWITCH, IT WILL STOP BEFORE SPINNING OR DRAINING.
WAS THE TIMER IN THE OFF POSITION OR WAS IT STILL IN THE MIDDLE OF THE CYCLE? IF IN MIDDLE OF CYCLE, POSSIBLE BAD LID SWITCH. IF AT END OF CYCLE, POSSIBLE BROKEN BELT OR MOTOR OVERLOAD TRIPPED.
TRY MOVING THE TIMER TO THE SPIN POSITION AND SEE IF IT DRAINS AND SPINS. COULD ALSO BE A RESTRICTION IN THE PUMP OR TUB NOT LETTING THE WATER OUT.
Posted on Mar 27, 2008
  • 185 Answers
Check the lid switch
SOURCE:
I have a frontload he washer. My question is, will using a regular laundry detergent instead of he laundry detergent cause problems with the washer.
top load detergent will suds a lot and detergents made for from load washers wont suds very much at all, suds ina front loader will cause it to not spin or drain very well while i know it is more expensive you should always use detergents with the HE logo on the package
Jul 25, 2011 | Washing Machines
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer 417-44082400
Check your ettings
one of them has been changed
try using different settings till you get the right one back
otherwise your timer my be malfunctioning
Jan 18, 2009 | Washing Machines
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Won't spin.
Your washer obviously has been over-loaded. It trips the spin switch & prevents top-speed spinning. See that you load within the machine's user manual load, not more. You can even weigh your laundry before loading to see that you dont over-load. Also see that the laundry is evenly placed within the bucket. These are suggestions.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
