Question about Samsung Digimax A503 Digital Camera
Camera will not stay powered on
Changed the battery, and camera is not staying on. First time it's ever done this. Don't know what to do now. Have cleaned any "residue" buildup off posts and inside the battery compartment, it stayed on a sec longer but then shuts its self right off again. Can't afford a new one, and can't afford to take it anywhere. Any tips would be great. Thank you in advance to anyone who replies.
    Brigadier General:
  • 11,967 Answers
Might be a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 08, 2010
I recently won an E10 in an auction. I did not receive any paper work or anything with it, so I don't know a whole lot about this little camera. But what I do know is that when I turn it on, it go
There are other complaints all over the internet about this cameras' battery life. Are you using NiMH batteries or alkaline? If you used 8 you must be using alkaline. If they are heavy duty regular batteries you are using the wrong kind of battery. NiMh hold more power and last longer with a flatter power curve up till they are about done. Recahrging means not buying lots of batteries too. They should last for a long, long time; like a week or two at least. The manual and quick guide can be downloaded in PDF from http://www.ricoh-imaging.co.uk/en/Photo-Downloads.html
Jul 22, 2012 | Pentax Optio E10 Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
Light indicated low batteries even though I changed
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 24, 2009 | Bushnell Trail Sentry 11-9200 Digital...
DXG-301V Power won't stay on
laistrop,
The fact that your camera was not used for a year and assuming the batteries remained in the camera (uncharged?) after that long a period of time, it would be very likely the batteries have deteriorated and may need to be replaced. The first thing to try is charging the batteries if you have not already done so. Plug in the charger and allow at least 12 hours for the batteries to charge. If the camera still will not work, the original batteries have very likey lost their ability to hold a charge and will have to be replaced. To test this, without spending too much money, try inserting 4 Alkaline AA batteries in the camera (observe the battery polarity marked on the flip-top battery cover). If the camera works, you should replace the batteries with fresh NiMh rechargeable batteries and charge them before you attempt to use the camera. Allow at least 12 hours for the initial charge unless the battery manufacturer suggests otherwise. I would not recommend using any form of "rapid" or "quick" charge rechargeable battery. If you do, you will be paying extra for a convenience you will not use, unless you plan to use an external quick charger, since the camera is not equipped to support rapid battery charging.
Rega
Feb 17, 2009 | DXG Technology DXG DXG-301V Digital...
Fisher-Price Kid-Tough Camera won't stay on
digital cameras have always "eaten" batteries. tho there may be an internal defect in the camera i would suggest purchasing a good set of rechargale batteries and charger for them.
Robert
Jan 10, 2009 | Fisher-Price Kid Tough Digital Camera
Camera won't come on, screen stays black, and the lens is stuck out.
it could possibly be the brand of batteries used sometimes they are not juiced enough to hold out for the camera i have had this problem too i used different batteries til i found one that works
Sep 30, 2008 | Samsung Digimax S630 Digital Camera
Time not staying in memory when batters are changed
Some of the old camera phones as well as cameras, really lose their time and date as the memory doesn't have power to run it. Some of the new cameras store some power so that the time and memory stamp has enough power to stay on till the battery is replaced. I don't know what your camera is but the time not staying in the memory is normal in some cameras.
Jul 15, 2008 | Cameras
Cybershot sont 7.2 mega pixels optical zoom 3X- camera will not stay on
i need to by chargar and connecter for camputar for my DSC-W55 wher and how much is cost ?
Jun 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
camera might have a hardware issue, possibly parts need replaceing, dont know of repaircosts. But I would recommend takeing the camera to a local pc or electronics repair shop for analysis. If no warranty exist anymore.
Feb 11, 2008 | Polaroid A500 Digital Camera
DSC 40 powering problem
I'm having a similar problem with a DSC S60: The camera will turn on in preview mode, but powers off as soon as I switch into STILL or VIDEO mode. I've changed batteries, done the full reset (remove the batteries and then hold the power button down for 15 secs.), and initialized all setting to factory defaults from the menu, and still get the same behaviour.
Sep 10, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Samsung Digimax A503 Digital Camera Logo
79 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
