Question about Rio Nitrus MP3 Player
"RESTARTING" My Rio Nitrus shut down with a message UPGRADER . The Web Site said to upgrade the firmware which I did and it seemed to work ok. Now it says "RESTARTING" but will not restart or turn off
  • Daisy20081 Apr 07, 2008
    I agree. it seems to be dead now. OH well I have purchased a new one. thanks
I encountered the same issue with my Nitrus. After following instructions to upgrade firmware, I had the "restarting" message on screen. I then took the unit apart once again. I could hear the drive making a noise. I tapped on the back of the drive with a screwdriver and the player started working properly.
Posted on Apr 07, 2010
Hi, it seems I have a similar problem after my Nitrus fell. I think the disk is defect. I once had this problem before and could solve it by downloading new firmware and formating the disk. I tried this again this time, but when trying to download the firmware it stops with the message Ok but in addition it says timelimit has been reached. Seems it didn't work. I guess the disk is really broken this time for my player.
Greetings from Germany
Posted on Apr 06, 2008
    Guru:
  • 155 Answers
If your Hard drive is broken then try reading:
http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon
This will tell you about my experience with replacing the hard drive with a CF card.
Mowcius
Posted on May 14, 2008
  • mowcius May 14, 2008
    I forgot to mention...
    I know that what I did was with the Rio carbon but as far as I am aware the Rio nitrus just uses a 1.5GB Microdrive rather than a 5GB one and has different buttons. Therefore replacing the hard drive should still work
    Mowcius
RIO Nitrus
It says "upgrader" because it is looking for a firmware upgrade - you will not be able to get rid of this message without doing the firmware upgrade - go to the rio website and follow the instructions for doing a fimrware upgrade - the msg will be removed, and you will be good to go
-Tha Mp3 Doctor
May 28, 2008 | Rio Nitrus MP3 Player
Upgrader
can u upgrade the firmware and software uuse for it from the website maker ok save the update sto the hard drive then installl
Jan 26, 2008 | Rio Cali Sport MP3 Player
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
Feb 27, 2008 | Rio Nitrus MP3 Player
Rio Carbon Stuck in Upgrader Mode
Hi Allyson,
This is a problem which I have encountered alot with my Rio Carbon.
A solution which always works for me is to hold the player face down in my left hand and then slap the back of it with my right palm a little harder than I would if I was winding a baby.
Best wishes, I hope this works for you as it does for me.
Feb 17, 2008 | Rio Carbon MP3 Player
Rio carbon upgrader message
Hi Linda, Your Rio Carbon is telling you that something is messed with its firmware and it can be resolved with an upgrade. You have to determine the exact model of your unit and download the firmware from http://www.digitalnetworksna.com/support/rio/. Again you must choose the exact model. There are two ways of updating firmware updater or internet updater. complete instructions are also available. further you would need to connect your Rio to a PC to perform the upgrade. Good luck and pls post back should you need further information. Kind regards.
Aug 20, 2007 | Rio Carbon MP3 Player
Player says "restarting" but never restarts
look for a small pinhole to reset the device..to bad RIO did not provide a way to "go back" in case of failed firmware
May 28, 2007 | Rio Forge Sport Digital Media Player
My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Upgrader message
I've had the same thing happening and have been scanning the net for help. I finally got the player up and running, although I've lost aaaaaaaaaall my music....but at least I can stop shopping for a new player (for now). It was suggested on another site I plug it into the wall and keeep hitting reset and power in any random order. I would get strange things happening but it finally went back to normal and is now working again. There was no formula, just keep playing with the power and reset while it's plugged into the wall. I hope this helps.
Dec 13, 2006 | Rio Carbon MP3 Player
Rio 258 cannot connect to computer
I know this request is old, but I found it while searching for an answer to the same problem myself. First you need to go to the Rio site and download the most up-to-date firmware. it DOESN'T matter if it's the same version that you have now, you will need the installer program. Download that and install it. Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen. Now, run the firmware upgrade program and it will see your player and upgrade the firmware (yes, even if it's the same firmware version. You have to do this step). Once it's completed, unplug the player from your computer and the darned thing works.
Jun 30, 2006 | Rio Forge Sport Digital Media Player
MUSIC WON'T PLAY
Rio confirmed that there are fundamental problems with the firmware update, some people reffer to it as the "upgrader bug" . You should get Rio to replace it for you, if you can't fix it with a firmware upgrade. when you talk to them, say you saw thousands of posts about this upgrader thing on the net, and you realize its a known issue. In full sympathy, SG ;]
May 03, 2006 | Rio S10 MP3 Player
Rio Nitrus MP3 Player Logo
292 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
