Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Sears 5.5 lawnmower, oil spewing up onto deck from oil fill tube.
Not overfill, oil is comming up from resivior onto deck while in operation. mower was gift, not used in 3 years. solutions?
    Problem Solver:
  • 8 Answers
Drain some oil then screw the lid on
Posted on May 09, 2010
CARBURETOR LEAKING OIL AND SMOKING
IT is likely that the carb is leaking fuel and filling the crankcase with fuel. Causing excessive crankcase pressure forcing oil into airbox through the crankcase vent. Check your crankcase for fuel and/ or being overfilled. If fuel is present fix the carb first, then drain and refill crankcase. After all is fixed run the unit outside for a few minutes and let it burn off excess smoke.
Sep 02, 2014 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Brand new mower smoking on first start
tie a rope on the handle and allow it to run for 5-min with no load on it if it doesn't clear up then return it to the store you bought it at
Aug 04, 2012 | Garden
Under load my tecumseh 6.25 lawnmower engin leaks out all over the deck ???what can I do to solve this???
Did you over fill the engine with oil?Some times the seal where you put oil in the engine is bad.You should be able to see where its coming from.
Aug 24, 2011 | Sears Garden
Where is the oil drain plug
The drain plug on a Briggs and Stratton engine is underneath the deck. Most likely it is concealed by cover for the self propel belt and possibly the blade as well.
The suggested method for draining the oil is to warm up the engine by running the unit for 10 minutes or more, though this should be sufficient time for the engine to have warmed up. Then drain the oil.
An alternate method is to drain the oil out of the oil filler tube. To do this, after the engine is warmed up, tilt the mower onto the side that has the oil filler tube. Put the drain pan under the filler tube, then remove the filler cap. The oil will drain out into the oil drain pan.
CAUTION: The oil that will come out of the engine will be HOT! So be careful when removing the oil filler cap.
I hope this will answer your question. Best of luck in this mowing season.
Apr 04, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Clippings not going into catcher...dropping onto lawn
ck the outlet of the deck and any connection between the deck and bag for debis build up.
Sep 13, 2009 | Garden
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Constant white smoke while running
White smoke is oil burn off. First off, check the oil level (sounds dumb, I know) and make sure the oil is not overfilled. Overfilling would be the easiest solution. If there is oil burning onto the spark plug but the oil is not overfilled, I would think rings... possibly scarring in the cylinder. Something allowing the oil to seep past the piston into the head. If the cylinder is scarred, there are .020 oversized pistons and rings available for the engines, rebore the cylinder and place those in.
May 16, 2009 | Parks Optical 13.5hp Briggs And Stratton...
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
445 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
