Question about Peg Perego John Deere Gator HPX Ride on Toy
How do I get the back to dump - is there a lever somewhere?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Red lever behind the seat, unless you have the optional motorized dump kit
Posted on Aug 14, 2017
How do I empty the tank instructions do not say
Looks like you have a bagless vacuum. The other kind have a tank. The tank can usually be removed by pressing a lever or switch somewhere on the top area of the tank.
When you get the tank off, it will come apart easily. Try to remove the top of the tank. Then you can dump it out into the trash. Watch how you open and removed the tank so you can put it back together again.
Hopr this helps.
Feb 02, 2015 | Vacuums
Tip
Dumping dry grounds and not making coffee
Dosage lever or knob is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click back from the full positive, and that should take care of the problem. Another thing that can cause this is the grind is too coarse or the grinder has come apart. The grinds should look like coarse sugar.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping dry grounds.
on Feb 08, 2010 | Coffee Makers & Espresso Machines
Tip
Superautomatic does not make espresso. Dumps dry grounds
Dosage lever or knob is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click towards the minus side, and that should take care of the problem.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping.
on Dec 17, 2009 | Coffee Makers & Espresso Machines
My Royal professional cappucino machine does not let out any coffee, we press the button and there is a louder noise of grinding and then it is as if it grinds the coffe but no water goes through and the...
Hi
There is a lever at the top of the door on the right side. Pull the lever back 1 notch from the plus (+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it. Never push the lever all the way or it can cause this overcharge. Its fine if the brew group is clean but when you make coffee there is always a residue left and this is what causes the overcharge. The lever in on or behind the door, NOT under the bean hopper!
Also if the grind is too coarse (french press) this can also do this, and that means that the grinder has seperated. New grinder.
Apr 26, 2011 | Saeco Royal Professional Espresso Machine
Hello, I have the problem that in about 30% of the cases where i press the coffee button, it will start grinding the beans and after it is done grinding, it stops and no coffee comes out. It is descaled...
There is a lever at the top of the door on the right side. It may be inside. Pull the lever back 1 notch from the plus (+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it. Never push the lever all the way or it can cause this overcharge. Its fine if the brew group is clean but when you make coffee there is always a residue left and this is what causes the overcharge. The lever in on or behind the door, NOT under the bean hopper!
Oct 26, 2010 | Saeco Magic Comfort Plus Espresso Machine
Tractor Front end loader will not dump. JD 2320 tractor front end loader .
Could be a lot of things. Quoick coupling loose? Does the lever work from left to right? Is it stuck now and only work from front to back? There is a small lockout feature on it that keeps from it moving when you hit it with your legs. It is down at the base of the lever. Other than that has to be connections. Try swithching the hoses around where up and down is dump.
See if its that
May 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
When pushing button for a cup of coffee to be made - the beans are grinding and dumping in the box - however no water is coming thru to empty into my cup - the water is being dumped into the reservoir...
Hi
Dry grounds dumped.
There is a lever at the top of the door on the right side. Yours is actually inside the door on the machine. Pull the lever back 1 notch from the plus(+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it, or breaks the drive gears. Never push the lever all the way or it can cause this overcharge. Its fine if the brew group is clean but when you make coffee there is always a residue left and this is what causes the overcharge.
Oct 24, 2009 | Saeco Magic De Luxe Espresso Machine
Icemaker is not dumping ice. Lever is in the down
the heaters go south in the tray and cant eject , need new one
Aug 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
The machine grinds the coffee and dumps the still dry grounds into the dregdrawer. No espresso made. I have cleaned and decalcified the machine. I got a few shots out and I'm back to the same problem --...
Hi
There is a lever at the top of the door on the right side. Pull the lever back 1 notch from the plus(+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it.
Jun 30, 2009 | Saeco Royal Professional Espresso Machine
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Peg Perego John Deere Gator HPX Ride on Toy Logo
130 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
