Question about Troy Bilt 5.5hp Self Propelled Mower
How do I change the rear wheel on my Honda Harmony HRB215 FB mower? I need to replace a rear wheel on my Honda Harmony HRB215 FB lawn mower, but I can't get it to fit back in place, interlocking the gear inside the wheel with the gear mounted on the motor. I have no repair manual, and that information doesn't seem to be in the owner's manual I saw online. Help!
panilling9
  • 284 Answers
SOURCE: Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
Posted on May 25, 2009
#1 Taper
  • 1040 Answers
SOURCE: Need help with belt on Troybilt self propelled push mower
Try removing the pulley in order to put the belt back on.
Jim
Posted on May 30, 2009
woobie dog
  • 1273 Answers
SOURCE: trot bilt rear self-propelled lawn mower, squeaky
Check the front axle, where it mounts to the frame. Spray the channel with white lithium grease (auto parts supply, W/Mart). My axel has a single bolt that holds it to the frame, and will make noise if I don't keep it lubed, especially in the area of the bolt. Hope this helps!
Regards, --W/D--
Posted on Jul 12, 2009
spekgt
  • 60 Answers
SOURCE: Honda Harmony II HRR216TDA drive clutch cable snapped
First put the machine on the side with the muffler facing the floor . Right behind the rear wheel you have a 10mm bolt that you have to remove and look for another 2 10mm bolts holding the plate that you remove the first bolt (one should be at the bottom and the other one on the side) .
Slide that plate out of the machine and now you be able to see the belt that goes to the transmission and also the drive clutch cable.
Hope this help .
Posted on Aug 29, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
My honda harmony II model number HRR2168VYA rear wheel won't turn backwards, they move forwards just fine.
If you remove the wheels, there are little keys under spring pressure. The grease lubricating them hardens over time. Clean this out with toothpicks and brake cleaner, reassemble with some wheel bearing grease or grease from a lube gun, and it should work just fine, otherwise maybe the trans has a problem.
Jul 09, 2016 | Honda Garden
What size socket wrench to change spark plug in husqvarna push mower
www.husqvarna.com/us/support/
Measure it by using an adjustable wrench and a tape measure.
Oct 12, 2014 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Have Honda HRB215 mower. Fired right up first use this season and operated fine. Week later fires first pull then dies after couple seconds. Drained gas and replaced, checked fuel filter, gas lines etc....
Have you checked the spark plug? Mine was doing the same thing. Not staying cranked and sputtering while running. I changed the plug and it runs like new. Hope this helps
Jul 11, 2012 | Garden
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Honda Harmony mower starts but will not stay running
rebuild the carberator. easier said then done huh. anyways, thats your only soluation. hope this helped you
May 28, 2010 | Honda Garden
Rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troy Bilt 5.5hp Self Propelled Mower Logo
383 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
