Question about Sony CMT-CP11 CD Shelf System
Power Loss To Amp.
Hi.
The Amp section is not working on my CMT-CP11. There is power going to both the CD and Tape player but none of the switches or lights work on the amp section, and pressing the power button has no effect.
Many thank
Dave
  • yarvh00 Apr 22, 2009
    My CMT-CP1 powers on partially. I see the "Welcome" message but nothing else happens. I open the box and check the fuses an they all seem ok.
    Any hint will be appreciated
    Roger
    Sergeant:
    Champion:
  • 319 Answers
Apparently there is a blown fuse in amp. May just require replacement but you should watch for what may have caused it to blow
Posted on May 08, 2008
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
Stuck in standby
You can reset all to factory settings, which may help; unplug power, put back in switch on with power button. Then press together "tape", "CD" and the power button. You may need to reset the clock before it will work. If you need the manual, here is the link; http://pdf.crse.com/manuals/2048589112.pdf check page 26 for the reset if not clear - nothing else in there that seems to be related, but you may find something i missed. Hope this helps :)
Jul 01, 2007 | Sony CMT-CPX11 CD Shelf System
My car radio,cd,tape player and clock does not work
hi margie, your fault lies with the power line feeding both your clock and car radio units. check the fuse of the line feeding your radio/clock section. the fuse box should have the areas clearly marked. also check if the ground connection to radio/clock is not diconnected sumhow. if this advice does not help then it wub advisable for you to consult with nearest auto-elecrician. cheers.
May 22, 2012 | 2000 Ford Windstar
Is there any way to programme the preset radio without the remote control ?
Once you have selected a channel, hold one of the preset buttons down for 3 seconds, That will store that channel
Aug 20, 2011 | Sony CMT-CP11 CD Shelf System
On my sonamp 260 when i hook up my cd or tape player to the amp i get no sound from the speakers out but, i get a little sound from the line out
I reckon the line out is for connecting the pre-amp section to a powered amp. Which is why you are hearing the weak signal. In which case it's clear to me that for some reason the power amp section in your Sonance is dead! Since it's a stereo amp it's something that has killed both channels. Like a power-amp IC such as the picture I'm posting below. Or something else that is accross both channels, but not the pre-amp section.
Aug 27, 2010 | Sonance Sonamp 260 MKII 2-Channel...
I have problem with my sony cmt-cp1 model. NO DISC
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 08, 2010 | Sony CMT-CP11 CD Shelf System
Radio working but CD isn't
how long have you had it?......is the cd burnt?....................does any cd work?.................maybe there is short or some thing, if you just bought it take it, or maybe u should replace it
May 08, 2010 | Sony Audio Players & Recorders
CD is not playing on my SONY Home Audio CMT-EH15
HI. that grinding sound is signaling a lens assembly issue. the linkage and gear assembly seems to be jammed. this assembly must be able to move freely i order for the lens to track the CD. if the lens assembly is stripped or jammed, it will not be able to read and it will shutdown into stand by mode to prevent the motor from damaging itself. its most likely gear failure.
Unfortunately, the repair parts for this unit are only available from sony repair depots and, you will need to contact sony manufacturing in order to receive a repair ticket.
May 19, 2009 | Sony Audio Players & Recorders
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Sony cmt-ex1 CD verical loader
If your two speakers are working,if ok ,then the problem is in power amp section ,the IC chip there is already defected .changed that IC so it works normal again and some reheating works in power amp.section...
rate me as FIXYA
Jul 03, 2008 | Sony CMT-EX1 CD Shelf System
Sony CMT-CP11 CD Shelf System Logo
224 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
