Question about Nikon D70s Digital Camera
Focussing My problem is about focussing the subject. If three or more people in the frame where should I focus?
  • Nikon Master
  • 3,287 Answers
If they are located different distances from the camera, align the point of focus on the individual you want in focus. You can increase the the range of focus somewhat by changing the f-stop value to a higher number (like f 22). This could bring objects in a wide range of distances- say 20 feet to infinity - into focus. With a lower value f-stop (f 3.5 for example), the range of focus will be much smaller, say 20 feet to 30 feet. You'll have to take the camera out of AUTO and set to A or Aperture mode to do this though. Good luck!
Posted on May 08, 2010
Testimonial: "Excellent"
My canon T3i wont focus with either lense?
Most likely your camera is set to M manual focus. There's a little switch on the side of the camera that has S/C/M. The S is for single servo focus so it focusses on one subject and does not re-focus. The C is for continuous for action and movement and the camera continuously re-focusses, and the M is manual focus.
The other possibility is that both lenses are switched to Manual. There is a switch on the lens that says M/MA. Be sure it's on MA
Aug 18, 2014 | Canon EOS 600D Rebel T3i Digital Camera...
I have a canon xsi that I have been using successfully for a year and a half. All of a sudden the focus preview is not working. It doesn't matter what lens I am using. I shoot in manual mode. What I...
When you depress the shutter button halfway, you are (in fact) activating the focus mechanism.
If in AF mode, you should hear the 'beep' when focus is achieved.
However, bear in mind that the XSi has three focussing modes: Quick mode, Live View, and Manual. There is a difference in how focussing is achieved between the Quick and Live View modes. (see page 102 onwards of the user manual "using AF to focus").
Also, the barrel of the lens will move during the focus operation.
If this does not happen, then there is a definate problem.
Having images in focus despite having no movement on the lens, simply means that the aperture settings are probably small enough to give sufficient depth of field to include your subject.
Jun 12, 2011 | Canon Cameras
Im trying to take closeup pics of jewelry, which is the reason I purchased this 12x zoom. I am using the super macro feature but my pics are blurry. Can you give me any tips? Deb
In super macro mode, there is a minimum focussing distance. Any closer, and you have no hope of locking in a focus. So, be sure you don't go past this point.Close up pics have a very shallow "depth of focus" meaning that very little in front or behind what you focussed on will be in focus. Is anything in focus in your pics? If you can exert some manual control over lens openings, you could try using a smaller opening to get more of your subject in focus. When taking close-ups, always use a tripod.
Dec 01, 2010 | FUJIFILM Finepix S1500fd Digital Camera
My camera will not focus. I have a 50mm lens and 200mm and neither will focus
Which exact lenses are you trying to use? The N2000 (aka F301) is a manual focus camera so if you're trying to use autofocus lenses you have to focus them manually. Sorry if this seems an insulting suggestion, but you did state "my camera will not focus" and I've learned that on FixYa it's best not to assume any prior level of knowledge with regard to those who post questions.
The next thing to check is whether the viewfinder has an eyecup attached, if so slide it upwards to remove it as sometimes they have a corrective lens fitted if the previous user needed corrective optics. If your vision is fine (with glasses/contact lenses if necessary) then a corrective lens on the viewfinder may make things look blurry.
Other than that, the only other possible cause (other than a pair of broken lenses) is if the focussing screen has become dislodged downwards (or somehow fitted upside-down) then the viewfinder image will be unsharp. Officially the F301/N2000 had a fixed focussing screen but it could be replaced with one of three designed for the higher specified F501 (which does have autofocus), and if not seated correctly you'd get the focussing issue you describe.
You can test if the focussing screen is the problem in one of two ways:-
1. A visual inspection (you may need to get a more experienced photographer to take a look at it);
2. Set the lens to focus at infinity and at the widest possible aperture and take a photograph of a distant object (ignoring the blurred viewfinder). process the film and inspect the photo. If it's sharp then you have a focussing screen problem. If not, then it's a lens problem.
If the problem is a poorly fitted focussing screen then it may just need reseating or to be removed and refitted. It's vital to do this in a dust free environment and to avoid getting fingerprints on the screen. Some screens sit in a hinged frame which then clips into place when pushed up, others push into a pair of clips towards the top rear and then the front is held in place by a spring clip: it's been a long while since I worked on the F501 or F301 so I don't recall which system is used.
Courtesy of Norman Butkus' website, click here for a free Nikon N2000 user manual.
I hope that you've found my answer to be of use, if so please return the favour by rating my answer.
Feb 06, 2010 | Nikon N2000 35mm SLR Camera
Canon Ixus 75 Auto Focus fails. It appears to be trying to focus and the small box appears on the screen showing where it it trying to focus. I think it's always focussing very close up. Macro is not set....
This usually happens when there's not enough contrast between the subject and the background or the subject itself is too 'flat'.
Also if there's not enough light in 'flash off'-mode you cannot focus. Try using the focusing assist light.
Dec 11, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera has focus error. How to solve the problem?
Performance wise, the camera has a couple of niggles. Start up to first shot time is around a second, and shot to shot (without flash) is good with three shots (the top three or the last three in a sequence are captured) in around 1.5 seconds unless the camera needs to refocus ort the flash fires. Flash recharge is around five seconds and disappointingly, the camera locks up as the flash charges, which is a shame.
But, focusing becomes an issue in low light too, where the camera will hunt trying to key on the subject or just continually fail to focus. So, beware in low light. There was another focus niggle on smaller subjects in macro mode where the camera would simply refuse to focus on anything in the frame smaller than the central AF area, and no matter what you do. Thanks
Oct 12, 2009 | Fuji FinePix Z100fd Digital Camera
Focus problems with Nikon D700
use center fous mode dont keep multi focusing mode
Jun 17, 2009 | Nikon D700 Digital Camera
Stiff focussing wheel on Zeiss binoculars
like me and you with age we all get stiff...sounds like it has been used alot and needs regreasing. the focus wheel on the zeiss is a double washer type and that it why it is stiff, sometimes the washer between the two focus knobs gets broken....but im sure thats not it...just needs a little tlc ..if i can help any further give me a call @15082549726....surprised zeissman didnt answer thi
Apr 10, 2009 | Optics
Green focus box
It might be because u r working in macro/supermacro mode (u can see a little flower on top of the viewfinder/lcd display) and focusing on a distant object or u try focussing a subject placed very near the cam while working with non macro mode. If changing these doesnt solve ur prblm, plz provide full details of what mode u use, what u r focussing on, what is the lighting conditions u used, etc..
Dec 11, 2007 | Canon PowerShot S3 IS Digital Camera
How many focusing points are there provided in the camera to measure distance to a subject?
Normally the camera measures the distance to the subject using the 3 auto focus frames (left, center and right auto focus frames) in the viewfinder and selects the most appropriate point automatically. You can also select any one of the three points.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Nikon D70s Digital Camera Logo
80 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
