Question about Hayward 250kbtu Ng Pool Heater - Inground
Roll out my heater is rolling out checked the top it is venting fine the gas tubes are clean and it only does it some times
  • 767 Answers
Hello my name is Heath it will be by pleasure to assist you. Check the burners themselves. Also it may be the gas pressure is to high or the regulator isn't set right. Have someone check the gas pressure at the unit before and during ignition.
Posted on May 08, 2010
Rollout switch open displays
Fusible link or the Roll out switch are one and the same...
if it burns out, or provides 'Open Circuit', then you had heat or flame exit the front of the heater instead of up!
This is a problem that needs correction.
Most common reason, Sooted Heat Exchanger / Tube Bundle.
dissassemble and clean it - not with a brush!!!
2nd possibility, especially if outdoor installation is a 'Downdraft'.
Don't just replace rollout switch - FIX the reason it burned out!
May 24, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
What is the cause of rold out flames on gmpn 120-5 furnace
There can be many causes of this. First check to be sure you are using the correct gas type (natural gas or propane) for the heater. It may need to be converted to the correct gas type.Then check to make sure your venting is not blocked (bird nest, etc). Sometimes it's a soot build-up inside the chamber and flue, which can be caused over time due to one of the above problems I mentioned.
Mar 01, 2015 | Heating & Cooling
Raypak pool heater model 406A fault code rollut sw open
you had a flame roll out. thermal fuse is blown. you can buy one for about 10 bucks. then you need to clean the burners and inspect the heat exchanger and venting
Aug 17, 2014 | Raypak 406A Digital ASME Natural Gas IID...
Can you run your heater without a roll out switch?
The roll out switch is a safety switch. It is there for safety. The purpose of the switch is to cut the gas off if there is flame or excessive heat low in the heater as found when the heat cant exscape out the top. Many reasons for a roll out failure if you are tripping the roll out it is always a symptom of a larger problem.
Low gas pressure or lack of combustable air causes soot in the heater like that of a chimney. This will restrict the air flow through the heater. A spider web in the gas oriface or burner can cause a roll out flame to hit the roll out fuse. Indoor applications can easily be an issue with the exaust venting or fresh air supply. Outdoor applications it could be a wind down draft through the heater. Whatever the reason it is tripping the roll out fuse, by bypassing it you are allowing the gas and burn to continue in an unsafe condition which mean larger problems will arise possibly even the heater catching fire.
Jun 24, 2014 | Rheem Pool & Spa
Flame roll safety switch
check gas pressure if too low it will overheat replace and then clean outside of heat exchange so heat can vent out
Jun 15, 2013 | Raypak 130,000 BTU Propane Gas Pool...
Installed new heater it ran for 15 minutes and the gas cut off. The combustion fan and the fan keeps running, the only way to stop them from running is to throw the breaker. LED light blinks 4 times, book...
the high limit is an over heat switch that could mean the unit is over fired. you would need to time input or check manifold pressure. the roll out switch is a switch that shuts the unit off if combustion is spilling at the divitor on the unit where the vent connects. with this you need to check your venting
Jan 05, 2011 | Mr. Heater MHU75NG
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a 2004 jeep wrangler that wont accept fuel corectly it shuts the pump off no matter how slow i fuel it
there are two valves on top your fuel tank,
one is a roll over valve that will close off the fuel if the vehicle rolls over,the other is a vent valve that lets pressure escape while your filling it with gas,this valve is not letting the air that is going in the tank with the fuel vent out ,so it is coming out the only hole it has which is the filler tube.
Dec 28, 2009 | 2004 Jeep Wrangler
My heater works fine when its a little cold,when its freezing outside it heats for a couple of airs then it would come on and off fine but with cold air blowing.i looked at the codes it blinks 6 times...
do not adjust your gas pressure without an manometer or if you dont know what you are doing could be very dangerous. Roll out switches are manual reset if you have an open roll out on a Goodman furnace you probably have a cracked heatexchanger, get a qualified technician out there asap
Oct 06, 2009 | Goodman GMS90703BXA Heater
Hayward 250kbtu Ng Pool Heater - Inground Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
