Question about HP Pavilion dv7-1130us laptop
My HP DV7 laptop will no power on. The LED next
My HP DV7 laptop will no power on. The LED next to the plug in is lit but the laptop will not even boot up or even appears to have any electricity running through it
  • I had boot issues with my HP DV7. The guys athttp://www.generalsystemsconsulting.com were able to help me get mine fixed at a reasonable price.
    Guru:
  • 302 Answers
Try pulling the hard drive loose and see if it tries to boot and comes up with no boot device found if it does the hard drive is bad if not the bios is corrupted and will need the bios reflashed.
Posted on Jun 22, 2010
Power indicator blinking orange and white
Mym7 stops charging the battery every now and then to allow the battery to discharge. This extends the life of the battery and changes the state of the battery light.
Feb 21, 2014 | HP Pavilion dv7-7000 dv7-7023cl B5R45UAR...
Dv7 motherboard won't turn on
used good power jack and check for wrong soldering&tracks cat
then joint the power jack its work
Feb 09, 2012 | Computers & Internet
Dv-7 is not getting charged . even the white indicator on the side near charging port is not coming ON. checked the ouput of the adapter, its fine but as i hook it up there is no response .
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.Thiscan be repaired but it requires the laptop to be completely dismantled to getat this power socket and repair. If you cannot DIY then I suggest you get aquote first.
Nov 03, 2011 | HP Pavilion dv7-1245dx Notebook
I have hp pavilion dv7-1236ez when i power on it is start but it is not came disply
once the power button is pushed and the the LED indicator stays on
issues
memory : so try replacing them both or try them in the laptop one at a time as one may be bad and not both
cpu: will need to be replaced in a shop or a similar one, screw driver and time disabble and replaace
graphic
card on motherboard
long and short if u test the memory as suggested and cpu sttill no result
heres a resonable replace for mothherboard
http://www.ebay.com/itm/HP-DV7-1240EK-DV7-1236EZ-DV7-1240ED-AMD-MOTHERBOARD-/250879674075?pt=Motherboards&hash=item3a699806db
Sep 07, 2011 | HP Computers & Internet
I have HP Pavilion dv7-1240us laptop..since some days it is not power on..on respons..i have allready change battery.but still same problem..please give me some solution with picture..i m waiting for your...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 19, 2011 | HP Pavilion dv7-1240us Notebook
My HP dv7 laptop wont turn on I purchased a new battery and a new cord it worked for an hour then shut off again!!!!!!!!!!
Your DC connector is loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 01, 2010 | HP Pavilion dv6000z Notebook
Was using my Hp Pavilion dv7 laptop, suddenly turned off while the charger was plugged in. Turned back on then shut off again. Now my laptop wont even turn on, and there are no lights that even come on,...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | HP Pavilion dv7-1245dx Notebook
Hp dv7-1245dx does not get power when plugged in
First Check your Adapter, It should have LED glow if its working
Second check that your Power Socket is working fine or not. You can try to connect with different Power Socket.
If still its not working. Remove the Battery and connect the Power. Check if its working.
Please post your feedback and Vote if the problem resolved as per your satisfaction>
Sep 24, 2010 | HP Pavilion dv7-1245dx Notebook
I plug the laptop in to charge but it is not turning on
May be your charger is no working. If possible check with a new charger. if its working you can buy a new one.
Feb 18, 2010 | HP Pavilion dv7-1130us laptop
HP Pavilion dv7-1130us laptop Logo
1,117 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
