Question about Brother LS-2125 Mechanical Sewing Machine
Needle wont move up and down.
Turned machine on and the motor runs but the needle wont move up and down. Just moved and not sure it it was dropped or anything. dont know what to look for in fixing it myself.
    Genius:
  • 1,116 Answers
Check the settings for bobbin winding to be sure they are not activated.
Posted on May 08, 2010
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
How do I fix the mechanism for the needle. Needle barely moves and will not go down through fabric
If it is a mechanical machine, it most likely needs a thorough cleaning and oiling. If not oiled frequently, the old oil turns to a goo or varnish and prevents the parts from moving freely. Do not force the motor to try to run your machine as it will most likely damage the motor.
Might be best to take it for a standard service.
If you have the patience and time, you can try fixing it yourself:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 22, 2015 | Sewing Machines
I have a homemaker FY2300 sewing machine and it has seized it will only move enough for me to thread it but will not move after that. HELP
As complicated as they look, they are actually fairly simple in their operation. I know parts can wear out, but that is usually indicated by a gradual decrease in performance and an increase in noise. If a machine has seized it is usually for one of two reasons. It has jammed with dust and fibres from material or the timing is all wrong.
Open up and have a look at the inside of the machine and remove any bits, dust, threads etc that are accessible. It will benefit from oiling as well, but unless it is rusted it should move fairly freely by hand turning the wheel on the side. If it does move now check that the needle is going up and down and doesn't contact anything whilst turning the hand wheel. The needle tip will drop below into the shuttle but shouldn't touch anything and should come out again before the mechanism moves to block the needles travel. Do this for a few cycles and if it operates freely then put a drop of oil in the lubrication points.
If it is totally seized or the needle hits something then maybe a professional can help with a service.
Oct 08, 2015 | Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
Needle wont move on its own
First check to see if the machine is in bobbin winding mode. If you are sure it is not in winding mode.... check your motor belt. It's probably worn out or mis-adjusted.
Nov 02, 2012 | Singer 4423 Sewing Machine
Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
Jul 05, 2009 | Sewing Machines
The needle wont move at all?
Hello we had the same problem with our sewing machine. After playing with it we found there is a bobbin winding assembly lever that moves back and forth. By moving it the needle moved. This helped us. Hope it helps you. embreyR97@yahoo.com if you have questions.
Jan 05, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
368 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
