Question about Toshiba Satellite A135-S4527 Notebook
My laptop heats up and shuts down after a while . just started doing this, then turns on okay after an hour or so.
    President:
  • 1,851 Answers
Either the cpu blower is not working or the the air ventilation openings are closed. Use a brush to clean up all the openings for air flow all over the laptop. If possible use clean air under pressure towards the air openingsin co-operation with the brush cleaning. In case of using air under pressure, leave the laptop at least one hour after the cleaning to relax.
Start the laptop and check the results. In case of the problem still exists, the problem is at the cpu blower. In order to get at this blower you must open the laptop's case. Since this is not so easy I suggest to get the laptop at a technician asking for cleaning and checking the cpu ventilation.
In case you are capable of opening the case or if you come up with a problem, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 08, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
You CPU heat is too hot, just clean the CPU fan dusty or replace the Processor Thermal-Cooling Assembly. Or you can buy a laptop cooling stand.
See how to replace Processor Thermal-Cooling Assembly here : http://www.laptops-battery.co.uk/blog/how-to-replace-the-dell-processor-thermal-cooling-assembly/
Hopes that help you. Good luck
Posted on May 27, 2010
  • Jack Smith
    Jack Smith May 27, 2010
    Or this maybe useful for you :How to clean notebook cooling system.
    Good luck
    Guru:
  • 1,705 Answers
Your CPU is overheating, remove all power sources, turn it over an remove the bottom plate over the CPU.
It should be easy to find, there's a ventilator grill in the case nearby.
Then clear out all the dust and rubbish, a natural bristle paint brush is the best tool. Making sure all the dust and fluff is removed from and internal venting ducts.
Put it all back together and try again. Oh and becareful not to cover the ventilators when in use.
  • 3 Answers
It is too hot,maybe you have to buy a new one, http://www.digi4travel.co.uk
Posted on Apr 11, 2011
After installing/uninstalling programs, my laptop should restart to complete the process, but shuts down midway. I'd have to leave it for an hour or so, before turning it on again; otherwise it'll shut...
Apparently seems like your laptop is facing heating problem & its because your cooling system including fan inst working properly. You need to check if your fan is running at adequate speed and also there aren't any dust particles stuck in head sink on either side of your laptop. All you need to do is just to use an air blower and clean the fins of your heat sinks to make the air flow properly. Good Luck
Oct 04, 2013 | Sony VAIO Computers & Internet
Laptop - Chooses when to turn on.
have you tryed formating it somthig could be conflicting somwere down the line if you can get it to trun on press and hold F11 you will lose stuff off the computer as it restors it bk to factory settings
Dec 05, 2012 | Computers & Internet
Laptop shuts down after around 3 hours
Sir,it is just because of overheating
open your laptop and clean your fan and heat sink or you buy a cooling pad so that it does not over heat
May 19, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Okay let me know what you think
the flyback transformer is the large black component simalar looking to a disrtibitor of a car it has a large red wire coming out of top and a black wire. On the bottom of the board it has about 10 pins arranged in a circle. this is flyback is located adjacent to the fuse.
Dec 07, 2008 | RCA HD52W59 HDTV Projection Television
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
Aspire 3610 fails to run for more than a few minutes
does the laptop get very hot ? Aspire know to over heat.
You also might want to reinstall OS.
May 08, 2008 | Acer Aspire 3610 Notebook
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
1,766 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
