Question about BenQ DC E53 Digital Camera
It says "sd door open" - BenQ DC E53 Digital Camera
  • 416 Answers
SD Door open means that the SD card Slot door is not clsed properly. open the slot remove the card & re insert the card & close the door.
Posted on May 08, 2010
Canon powershot A710 battery door won't open
If the SD card is housed in the same compartment, it is not loaded properly. The card holder is fitted with a spring mechanism to eject, therefore it will exert an outward pressure against the door. This will displace the locking/ unlocking mechanism of the door and will be impossible to open in the normal way.
Tips for opening, refer to my previous answers to similar questions.
Aug 24, 2015 | Canon PowerShot A710 IS Digital Camera
How to eject the card reader
  • Open the left door by sliding the lock open.
  • Find the micro SD card, very small next to the big battery.
  • push on the card to unlock it.
  • Put it in a micro sd adapter so it fits in your computer.
Easy does it!
Apr 08, 2014 | Kodak Cameras
Where to insert sd card polaroid a515 digitgal camera
Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the SD card into the slot located next to the battery bay. Close the battery door.
Apr 04, 2011 | Polaroid i830 Digital Camera
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
My Dad, 91years old, received a Kodak Easyshare model z1285 from a friend for christmas. no manual. He lives 400 miles away and called to ask if I knew where the SD card goes. Since I can't see the camera...
The door to access the SD card slot is on end of the camera which is closest to the round knob on the top of the camera.
If you turn the camera on end and look at the door, it has small groove in it that is about an inch long. Holding your camera in your left hand with the lens toward your palm, take your finger nail of your right fore finger and slide the door toward the back of the camera.
The door will swing open, revealing the slot for the SD card. When you get the camera, there may be a "dummy" plastic SD card in the slot. Release it by gently pressing the edge of the SD card and quickly releasing it. The card should pop up about a half inch and you can grab it with your fingers and pull it out.
Replace it with a fresh SD card, making certain that it is oriented with the label facing the back of the camera and the contacts facing the front of the camera. Gently push it into the slot until it seats. Don't force it. The card should go in with a little resistance, but does not require a lot of force to seat. Pressing it too hard will cause it to pop back out again.
If it doesn't seat properly, the card may be flipped the wrong way. The card should go into the slot contacts edge first, contacts facing the front of the camera and the label facing the back of the camera.
I hope this helps,
Art
Jan 01, 2011 | Kodak EasyShare Z12851 Digital Camera
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Sd card
Well, you can try removing the SD card and reinserting the card again. If you don't know where it is located, it is right below the green send key. If you look on the side of the phone there is a door that you can open if you open the keyboard. If that doesn't work, you may need to try the card in another device and try to reformat the SD card. Beware as this will delete everything on the card, but clear up any errors the card may have.
Jun 07, 2009 | HTC G1
Door will not open on a toshiba sd-6100. Its makes a grinding noise but will not open
there is a tiny hole next to the dvd door. Straighten out a small paperclip and push the end of the wire into the hole to manually open the door.
Apr 06, 2009 | Televison & Video
2 dvd's are stuck in dvd player
This may need a trip to the shop.
I would try to bring the device to a worktable and using gentle probes, ease the door open when activated.
I assume that there is a noise when you activate the door open feature.
Mar 21, 2009 | Toshiba SD-V394 DVD Player/VCR
Laptop dvd drive door will not open
There is a tiny hole on the draw in which to insert a paperclip to manually eject the draw.
Jan 16, 2007 | Compaq Presario X1000 Notebook
BenQ DC E53 Digital Camera Logo
52 people viewed this question
Top BenQ Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a BenQ Camera Expert? Answer questions, earn points and help others
