Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Remote control programming code
What is the programming code for Panasonic PT-51HX41E
    President:
  • 3,130 Answers
You can look up all the different codes in the remote manual. if you do not have that look up the codes for the brand of remote online or turn on the set and put the remote in the aearch mode and you might be able to find it that way. kind of dificult to tell you without the brand of remote you have!
techman
Posted on May 08, 2010
Panasonic PT-AE8000U discrete codes
go to www. remotecodelist.com and download for free.
God bless you
Nov 29, 2013 | Televison & Video
I have a Panasonic PT-51HX41E, and it will not power on.
does the power light blink? If so thats an error code let me know the number of blinks and I will assist you with the issue.
Feb 06, 2013 | Televison & Video
I have a panasonic PT-51HX41E 52" projection tv
A tech might be able to get into the hidden tech menu---sub brightness and sub contrast settings are there and it is not real easy to get into and does vary from model to model---access is with the original remote.
A suggestion if you can not or do not want to pay would be to search with Google and the model number for a "Service Manual" which will in it have instructions and indicate how, it will also have a list of items in that menu---be careful what you adjust there.
Dec 14, 2012 | Televison & Video
What remote is best for Panasonic PT-45LC12 ?
These are the universal setup codes for Panasonic TVs. You can select any brand universal remote control, which bears any one of these codes in its code list for Pansonic brand. Brand name of the remote isn't a matter. Check its code list, whether there is a code for Panasonic. That is all.
Setup codes for Panasonic are: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Aug 12, 2012 | One For All URC-3021 Remote Control
It turns itself off automatically.
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Jan 26, 2010 | Panasonic PT-51HX41 51" Rear Projection...
My panasonic pt-51hx41e will turn on for couple secs then turn off
hello. it sound like a power supply problem.!!! to me .!!! you can check it frist.!!!"good luck"
Aug 01, 2008 | Panasonic PT-51HX41 51" Rear Projection...
PANASONIC PT-51HX41E
The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Bill
Nov 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt-51hx41e tv screen codes
I found this on the net let me know if this works for you Once you are in service moce on a Panasonic you must continue through all steps to the end to exit. It starts with the B parameters, then C, S, and M, then you can exit by pressing power and action ON THR RECIEVER for 2 seconds. The TV will turn off and come back on on ch3 with sound. BTW, you advance thru the menus by pressing power on the remote.
Oct 05, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Broke reflection mirror
I would just replace the mirror part# TKG2AA50051 (about $115).I would not try to substitute an ordinary mirror.
Sep 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
