Question about Samson Servo 300 2-Channel Amplifier
Smoke in the back
I use this amp for my guitar rig, i think i've pushed too much last day and it started to drop some smoke, but when i opened it there wasn't any burnt at first sight and still works... i'm not shure where the smoke could come from. Sorry my english i haven't used it in a while. Any ideas?
p/d: i suspect of a little component that is above the power transistor, but not shure what it is.
    New Friend:
  • 47 Answers
If it still works leave it alone and use it as it is. Smoke usually comes from the emitter resistors of the power transistors if they're pushed too hard. Those resistors are about the only electronic devices that still work after you let the magic smoke out.
Posted on May 08, 2010
Testimonial: "ok. thank you very much, i'll do so trying not to push it that hard. very helpfull ;)"
I have a 98 blazer battery light came on and amp meter dropped I replaced the alternator work for a day and then did it again battery light on amp meter drop had battery checked and alternated check both...
With GM cars in general, I have found it is best to change the battery and alternator both out together. If one is weak it will take out the other in no time. These parts are both dirt cheap at a junkyard. Believe it or not, a junkyard delco alternator or battery is much better than a duro=last silver rebuilt in mexico.
You may also still have wiring problems remaining from the previous failure. GM dummy lights and gauges are notorious for being inaccurate, to the point that they hardly even function. At least rig up a volt meter that you can keep an eye on while driving, for a few days, to verify your alternator is actually outputting the right voltage.
Sep 20, 2014 | 1998 Chevrolet Blazer
I've only had my 714ce for about 5 weeks. I've used it for 4 shows and during my last show I experienced a volume drop. I unplugged the jack, plugged it back in and it was fine for a bit, bu
It's most likely the battery isn't producing enough voltage, though it may have been adequate for your other guitar.
However, you should discuss the issue asap with your dealer and/or Taylor support.
https://www.taylorguitars.com/support
Support
May 16, 2017 | Taylor 714ce Guitar Acoustic
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
My Behringer gx212 ultratwin amplifier started to lose volume last night at band practice and then I smelled buring wiring. I think I lost or am in the process of losing the amp transformer. I think the...
Hi I just recently purchased a Behringer GMX 212 and had similar volume dropout on the clean channel only Channel 2 works better and has more punch in clean mode.I went to the shop where I purchased it with a 7 day warranty from some indian dude here in Nadi Fiji, and there was another GMX 212on the floor so I decided to try it out. This was a new amp. I plugged into the clean channel and turned it up full volume on guitar and amp adn heard the volume drop of in the amp in almost a curve and then the whole amp just cut out. We unplugged and waited, turned the amp off, and then on and stil no sound. We then tried the guitar and cord in another amp. The other amp was fine. Can you solve this problem.......my gut feeling is this happens a lot to Behringer amps.
May 08, 2009 | Audio Players & Recorders
Just get clean tone through NI Rig Kontrol 2
you need an asio driver for your rig kontrol.. you are probably set to use DirectX drivers, which will give you latency of 50ms and waaaayy beyond... By contrast, ASIO drivers will give you sub-10ms latency... Most people can play at around 7ms, but im picky, and no more than 5ms will do for me..
Go download the drivers from NI site, and try those.. if that doesnt work, there is ASIO4ALL... google and read.,. this will help ya
keep playin
DJYoshaBYD
Sep 29, 2008 | Native Instruments GUITAR RIG
No effects
Double click on your speaker icon in the task bar next to the time (Or go to audio in control panel and find advanced settings)
Look for microphone and line in and mute them ...
Then click options, Goto advanced and choose recording and click ok ... Look for the input your using and turn that up as much as you need.
Then check guitar rig ... All should be fine now
Jun 25, 2008 | Native Instruments GUITAR RIG
Guitar rig
I've got an iMac and I've been trying to use my guitar rig with my new computer but the interfaces I tried so far ( Spike from Mackie and the US-122 from tascam ) they don't work at all even though they are supposed to work fine with my iMac.....which interface works the best on iMac so  I can use my guitar rig both stand alone or as a VST instrument?.......somebody there with some good suggestions?........thank you in advance
Nov 12, 2007 | Native Instruments GUITAR RIG
Samson Servo 300 2-Channel Amplifier Logo
82 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
