Question about Mitsubishi WS-65413 65" Rear Projection Television
Rolling screen pip mits 65813
Saw your fix from last year, but the link doesn't work anymore. Any idea where I could get a kit?
  • dpturner Mar 27, 2008
    Thank you for the links! I ordered both kit5 and 6 -- although I could have probably gotten by with just 6. Anyway, I doubt if these kits will come with a diagram of where the PIP unit is located. Do you know where it's located or where I could find that information. I have the manual with a map of the interior, but it doesn't designate the PIP. Thanks.
    Genius:
  • 1,153 Answers
What error codes are you getting, by pressing the menu and device/input button on front panel for 5 seconds? It should flash the code by sequence followed by a short pause then another set of flashes. This will be your error code.
Posted on Mar 27, 2008
  • Mitsubishi Master
  • 8,617 Answers
Matt electronics has the repair kit for the mitsubishi PIP module. Call this toll free number 1-800-628-1118 the item number is 61-170 on page 17 of their current catalog it sells for 13.50 It is referenced as the Mitsubishi MSD repair kit to fix the PIP module. It contains all the capacitors needed to do the repair.
    Master:
  • 788 Answers
  • Dean Joly
    Dean Joly Mar 28, 2008
    You can get the service manual for pretty cheap on eBay just search for "WS-65413 service manual" on eBay or search for it on google and you might find a free download of the manual.
    I think the board you are looking for is 930B875001 ASSY-PWB-SIGNAL. I beleive it might be a daughtboard to another board.
  • Dean Joly
    Don't forget to rate our solutions as you see fit. Thanks.
Mitsubishi WS-48311horizontal scroll
Its not a problem you can easily fix. Many Mits TVs of the mid-90's had a PIP board in them that had dried up surface mount capacitors on them. The board would have to be either re-built or replaced at a considerable cost.
michtech
Feb 12, 2009 | RCA P56923BL 56" Rear Projection...
Ughh....The TV doesn't work!
If the LED is constantly blinking green and the set wont start you there is an easy fix. you need the reapir kit called Mitsubishi V23 DM repair kit its abailable at the following link and has the parts and complete instructions with pictures so you can do the repair yourself. Heres the link its listed under repair kit catagory and its the V23 DM repair kit.
http://servicemanuals.vstore.ca/
Jun 12, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Mitsubishi TV WS-65713
you can get the service manual and detailed instructions on that repair by going to the following link.
May 31, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling Picture on all inputs -- PIP?
Did you replace with same size capacitors or did you change to what is required now, and what size was this?
Mar 27, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Rolling screen 65813
there is a small surface mount IC location num IC9C25 on the board next to the DM. it is at the bottom right corner if looking from the back. this a 9v regulator P/N BA09FP this might be your problem. be careful taking it off because you do not want to damage any traces. i suggest taking the input board off.
Mar 23, 2008 | Mitsubishi WS-65413 65" Rear Projection...
CS-27403
Older Mits TV's have a PIP circuit board that fails,upsetting the video....here is the solution....
1) Remove PIP PC board ..... discard
2) pull chassis... on underside of main board, locate VP plug
3) Using 22mf 50v NP capacitors, connect pin 5 to pin11
and pin 7 to pin 9......
large pix stable.....but no PIP box.....PIP PCB NLA......
.................T.
Jan 27, 2008 | Mitsubishi VS-45605 50" Rear Projection...
CC, SAP PIP
1) Try hard reset = unplug TV for some time,plug-in,try again.
2) Follow guide instructions carefully = one missed step is all it
takes
3) Consult owner operator manual
4) Further help? provide Model # off back of set..................T.
Jan 02, 2008 | RCA Universal Remote Control
Rolling screen
Ahh the old rolling picture problem. If this set has a Picture in picture feature, your problem is on the PIP module itself. There is a kit of surface mounted capacitors that need to be replaced If you have some soldering skills you should be able to do this your self, but if you do not, I advise you to get someomne who does as most of these PIP modules are not available any longer. The kit can be purchased from http://www.mcminone.com/search.asp?keyword=Mitsubishi+PIP+kit&btnSubmit.x=6&btnSubmit.y=7 Good Luck
Mar 28, 2007 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65413 65" Rear Projection Television Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
