Question about Whirlpool Duet GHW9150P Front Load Washer
It gave me an F-22 code
I cant find my books to gigure out how to get the door open or try to fix it
  • 5,911 Answers
"F22" is a door latch error code. The following link explains some of the common causes of this error, how to troubleshoot and the replacement of the door latch (if required):
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
If the door will not open, there are instructions included on how to use the manual release to open the door.
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams.
Read through the information and let me know if you need assistance beyond what the tech sheet provides. I hope you find this information helpful.
Posted on May 08, 2010
Fisher Paykel Dryer Fault Code 22 Info
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
Feb 10, 2012 | Fisher and Paykel DE27CW1 Electric Dryer
Can not open driver door on 1992 toyota camry. I cant get door open to remove panel to fix problem
IF YOU CANT OPEN DOOR FROM OUTSIDE TRY OPEN DOOR FROM INSIDE.I HAD THE SAME PROBLEM WHILE BACK.IF YOU CANT OPEN CAR DOOR FROM INSIDE,TRY OPEN CAR DOOR FROM THE OUT SIDE.
Jul 07, 2011 | 2006 Chevrolet Impala
I am trying to sent up a facebook account. when i try to login its telling me that a e-mail was sent (which it was with a validation code ) but when i go to sign in it again tells me to go to my e-mail....
hi, when you open the account with face book it asks you to enter an email address now this is the email address you use every day then what facebook do is send an email to the address you gave them when you registered with a link in it you then need to go to your email in box and click on the message then click on the link in the message, this will then take you back to face book and you should then have no problems using face book from then on.
if you cant remember the email address you gave them you need to try opening a new account with an email address that you do use.
let me know if you have any problems or need further assistance ok
Aug 23, 2010 | Computers & Internet
WHEN I PUSH TO BUTTON TO UNLOCK MY 2007 HYUNDAI VERACRUZ LIMITED, IT UNLOCKS OK BUT THEN WHEN I OPEN THE DOOR THE ALARM SOUNDS UNTIL I TURN THE IGNITION SWITCH. AFTER THAT, EVERYTHING OPERATES NORMALLY. ...
the car has two codes one is fixed the other is a rolling code which changes each time you press the unlock button,the first is allowing you to unlock the car but when you open the door it thinks your trying to steal it and the alarm goes off,then when you put in key it is recognising the key and switching off the alarm....NOW if you follow the instructions in the book you can reset the alarm(as i worked for hyundai over 5 years ago i cant remember the sequence,sorry)
Aug 21, 2010 | 2007 Hyundai Veracruz SE
Seats, Mirror's and horn do not work. A fuses are good, Cant find a relay. Any thoughts on what may cause this
open the drivers door; slide the rubber grommet containing the wiring to the door into the door; i wouldnt be surprized if you have multiple broken door wires; if so you should be able to get some 18-22 gauge crimp connectors to fix; had this problem on my 95 riv and it is a common prob on 95-96 rivs
Apr 08, 2010 | 1995 Buick Riviera
The door is locked after the wash cycle. The machine stopped, gave a code F-22 and will not unlock.
Possible cause , door lock mechanism is broken or removed from door. Unplug unit , then check harness connection to the door switch/lock unit and the central control unit(CCU)
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Feb 12, 2009 | Hotpoint Aquarius WD640 Front Load...
I have bought a remotec universal remote control that I cant seem to get to work on my Tevion TEV374 television. I have tried the 2 codes that came in the book and also an additional 7 that the **** smith...
THEY ALL HAVE AN AUTO CODE SETUP.WHERE YOU SIT THERE AND LET THE
TURD RUN THROUGH ALL THE CODES .lOOK UP CODE AUTO SEARCH,ITS THERE IN THE BOOK!
Feb 03, 2009 | Televison & Video
Error Code 56 and Yellow Status Light
check the error blink code again as 56 is not a valid error code for the WD62525
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Jan 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WS-65809 ERROR CODE 22
look on the center circuit board and you will see two green Pico fuses they look like resistors but they dont have any bands on them . They will have F9A04 and F9A05 on the board next to them. Check with a ohms meter if those fuses are open you will ned new convergence ICs. Thats the first thing to check are those two pico fuses when you get a 22 error on your model.
Sep 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
