Question about JVC Arsenal KD-AR5500 MP3 Player - CD/ MP3 / WMA / SD Card Receiver with with Motorized Detachable F...
KD-G632/KD-G631 I HAVE TRIED PUTTING THIS UNIT IN MY 1976 XJ6C. THE ELECTRIC AERIAL WILL NOT WORK. I KNOW IT WORKS PROPERLY WITH THE OLD UNIT, IT WORKS WHEN I JOIN THE POWER AND THE EARTH CABLE SUPPLIED BY THE CAR. !!!!!!!!!! WHAT CAN I DO????
5 Suggested Answers
DrElectrics
  • 199 Answers
SOURCE: Unit will not turn on
This seems like you have accidently rewired part of your electrics. You may have wired the power wire into the wrong place, and also wired your electric door locks into your accessories. YOU NEED TO BACKTRACK. Find you doorlock wiring and get it back to a constant power supply. Best bet is to wire your power wire of unit to cigarette lighter by splicing the wires or jacking the outlet at the back. Here is a guide to install your stereo. Following those steps and see if you went wrong somewhere.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Mar 19, 2008
  • 7 Answers
SOURCE: DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
Posted on May 28, 2008
SOURCE: iPhone to JVC KD-S690 Cable Connection
First step: pop a huge one.
Posted on Jan 27, 2010
  • 12 Answers
SOURCE: jvc kd-g340 rear speakers not working. I recently
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Posted on Mar 31, 2010
How to remove power antenna on 1976 cadillac eldorado convertible to have it repaired
These are usually held to the body from underneath by a nut.check electrics first as the wiring loom are prone to cracking damage over time.also there is usually a plastic strip cog which can sometimes burr on the aerial motor which prevent extension and closure.it's is easier to replace whole unit with kits off eBay.
Feb 09, 2015 | 1976 Cadillac Eldorado
Where does the remote wire go on the kd-g632
you hook yhe remote wire to your amp..
Apr 13, 2011 | Car Audio & Video
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
I can't find an owners manual for my very old Frigidaire RE-94 wall oven. the oven powers on, but the heating element does not get hot-- so trying to assess if a new heating element would do the trick or...
I have the same oven. works perfectly since 1976. I have the owner's guide and the schematic which will direct you to the solution. you will need to pull the oven 1/3 out of the wall in order to access the electric controls and use a VOM to check voltages.
Let me know what you need.
Curt
Oct 14, 2009 | Frigidaire Ovens
On a jvc kd-g632 cd player which wire port is for a remote lead for fitting an amp
The turn on voltage that the amp needs comes from the radio wiring harness and it is the blue wire that is in between the red and the white wires on most JVC radios.
Hope this helps and a rating of "FixYa!" would be appreciated for this free information.
Let me know if you need any more help.
Dave
Jul 21, 2008 | JVC Car Audio & Video
Mar 18, 2008 | JVC KD-G230 CD Player
Corrupt signal on Digifusion FVRT 150 DVD
Good day.
Due to the wind velocity in your area, I think you need to replace your aerial or you can check the wiring connection first from your aerial to the terminal on your unit because there are situations where breakage on wirings occurs due to stong winds.
chris
Mar 11, 2008 | Televison & Video
JVC KD-G631
Too much to type.
Manual is here;
http://www.coda.ru/manual/KD-G631(632)_rus.pdf
Page 12 and 13 have your answers.
Best of Luck.
Oct 15, 2007 | Car Audio & Video
Car Audio & Video Logo
51 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
