Question about Black & Decker Black and Decker CBG5 SmartGrind Blade Coffee Grinder - White
I need a new lid for my B&D SmartGrind coffee
The lid I have for my Black and Decker SmartGrind coffee grinder has 2 large chips that lets the ground coffee leak out during grinding. I'd like to find a replacement lid. The model #: CBG5.
4 Suggested Answers
SOURCE: Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Posted on Oct 08, 2009
SOURCE: I just want to know
How to Clean SmartGrind Blade Coffee Grinder - White
1. Always unplug the unit before cleaning. Wash the lid in warm, soapy water - not in a dishwasher.
Wipe the grinding bowl, base, and other parts with a slightly damp cloth or sponge. Take special care
around the blades; they are sharp! Dry parts thoroughly. Do not immerse grinding bowl, base or plug
in liquid or under running water.
2. Never use harsh detergents or abrasive cleansers or scouring pads to clean any
part.
3. To remove residue or aromas left behind by nuts, grind one tablespoon of baking
soda in the bowl then wipe thoroughly.
4. Use the built-in cord wrap on the underside of the unit to store the cord
Posted on Feb 09, 2011
ddinneb
  • 200 Answers
SOURCE: The tip on one side
I have two different coffee grinders and if it is just the tip of one side of the blades you can continue using it, if there is a large portion that is broken I'm not sure of that model. Hint: check to see if the part is still in the grinder set the grinder for the most coarse grind, don't turn it on, shake it upside down to see if the broken potion is still in the grinder. If you find nothing use the grinder unless the performance is less than you like.
Posted on Feb 10, 2011
The tip on one side of the grinder blade has broken off...the machine runs well and has not had a lot of use. Can the blade be replaced; if so, how, and how much? SmartGrind CBG5.
Feb 10, 2011 | Black & Decker Black and Decker CBG5...
Cannot replace the grinder knob after cleaning. Will not turn and lock
sad have the same problem and no one seems to be able to answe . or shoud I say "willing to answer"
Dec 30, 2010 | Black & Decker Black Decker CBM210...
I just want to know how to clean it after use - it is a coffee grinder, SmartGrind
part.
Nov 04, 2010 | Black & Decker Black and Decker CBG5...
I have Black & Decker Grinder Model CBM2 disrupted and wanted to fix it I could not open it. Opened the two screws and then opened the other three after the chair. But the lower lid was not opened....
  • after opennig 2 and 3 screws you should hold the shaft of motor with a screw driver from the hole on the lower cover and then turn the blade with suitable tool for opening the blade. after easily separate the lower cover from the body
Oct 18, 2010 | Black & Decker Black&Decker Coffee Grinder...
I need a clamp nut for a B&D angle grinder model #6247. Where can I purchase one??
The clamp nut for angle grinders have a standard thread.
It should be possible to get one at a large tool store. You may have to buy a new wrench for tightening the nut though.
Aug 30, 2010 | Black & Decker 4 1/2" Small Angle Grinder
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Ground Wire?
You don't. It's a double insulated tool.
Jun 12, 2009 | Black & Decker 4 1/2" Small Angle Grinder
CBM205S - Black & Decker Coffee Grinder
make sure the top cover is depresed fully. There's a safety switch underneath it.
Oct 28, 2007 | Black & Decker (CBM205S) Electric Grinder
Black & Decker Black and Decker CBG5 SmartGrind Blade Coffee Grinder - White Logo
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
