Question about Refrigerators
My refrigerator smells very badly at certain times....I have looked everywhere but cannot find the source. Could it be the drip pan internally?
  • 4,793 Answers
Possible but more likely to be drain pipe,use clorine bleach to blow it through,
Posted on May 08, 2010
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
Foul smell coming from behind the refrigerator. I smell it coming through the fan on the back of the refrigerator. I believe it could be the drip pan, but I don't know where it is located. Also, my...
the drip pan is usually on top of the compressor or has a draw underneath with a coil to create heat for evaporation of water from the drip pan. Some time a rodent can drown in this location.
Jul 17, 2017 | Whirlpool GB2SHDXP Bottom Freezer...
I have a Whirlpool refrigerator 21TFA that may have a drain problem or a clog. It drains in the evening, but this morning when I woke up, it smelled bad from the bottom of the refrigerator. Any advice?
Hi and Welcome to FixYa I am Kelly,
A bad smell from under the refrigerator is a result of either a dead rodent or.. dirt and lint accumulation in the plastic drip pan / catch basin and then the defrost cycle water wets it 2 to 3 times a day intensifying the smell.
Unplug the unit
Remove the rear fiberboard cover that covers the compressor area
Use a shop vac and rags to clean out the drip pan / catch basin. (These can be VERY foul if they have never been cleaned!) Make sure to clean the condenser coils and condenser fan area also. Inspect for varmits / rodents (deceased) with a flashlight. You can wash the drip pan using a rag with vinegar and water then soap and water.
Lastly... make sure the END of the drain tube that terminates in the drip pan is clean. If there was lint build up that caused a muck pool in your drip pan the muck often clogs the end of the drain line.
You never know what your going to find under a refrigerator! I could expound but it is not pleasant and only you will be able to discover the secrets of your refrigerators' "underside life." All I will say is.. it is always a... revealing experience.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Hello i am having a foul smell coming from underneath the refrigerator. it doesn't have the drip pan on it..i removed it due to a previous foul smell..are these refrigerators known to have this type of...
the smell is bacteria caused by condensation from the drain pipe/drip pan,syringe with chlorine bleach, all fridges will smell if not looked after in the proper manner....but how many of us read the book......(if you removed the drip pan then you have the bacteria all over your floor.....will discolour/ruin any surface/carpet...
Jul 30, 2010 | Admiral Refrigerators
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Smell developed in refrigerator, it is thoroughly clean
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first. It sometimes can be hard to find.
Jan 11, 2010 | Whirlpool GC5SHEXNS Side by Side...
Bad odor coming from drip pan when compressor kicks own[when dry]
I just had the same problem with my kenmore side by side. I have been noticing a nasty smell for the last couple weeks when the fan comes on. My husband just took the whole back of the refrigerator apart and put a flashlight in there. We could see the drip-pan and it was filled with stinky black mold!! It was very hard to remove, but he managed to get it out by taking the lower front (where the filter goes) apart and then he was able to slide out the drip pan and clean it out! Problem solved.....but Kenmore should really make the drip pan more accessable!
Apr 12, 2009 | Frigidaire FRS26ZSG
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
