Kenmore 70 series clicks loudly inside agitator like it is missing. It will agitate. It is like turn click click turn click click click turn. Not the rhythmic noiseless turns it had a week ago
  • 5,911 Answers
If its just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
If you have any questions, please post back with your MODEL NUMBER (located along the wash tub rim under the lid) and let me know. I hope you find this information helpful.
Posted on May 08, 2010
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
Bottom agitating, but top freely spins
You need to get an agitator repair kit. Remove the cap on the agitator. Some have a second inside plastic cover/cap. You will need a long extension and rachet and 1/2" socket to remove the hold down bolt. Remove and replace the parts with the kit parts. Replace the cover. 10 minute repair... online kit is about $13.00.
Aug 03, 2009 | Kenmore 24032\24036 Top Load Washer
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series barely agitates and makes a clicking sound
What u have just described are failed agitator pawls/dogs, relatively easy fix. The repair comes as a kit. Most appliance repair houses will have the kit, if not www.searspartsdirect.com will have them
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
