Question about Orbit Hardware & Accessories
Orbit timer model PN 57194 dosn't back off when start
Dear Sir, I bought new timer model PN 57194 & one valve only.
After fixing it & adjust starting time for 60 minutes, valve open on time & water go out.
After active timing finished, valve stay open & water stay going out until I turned main power off.
Please look into the matter & give your advice.
Best Regards,
Erfan
farfield
  • 462 Answers
SOURCE: Good morning,
First the thing that's causing the thermostat to act up Could be the thermostat being bad.
The blinking does it continue for hours on end and nothing runs? If so the thermostat LOCKED OUT. Now what caused this???
I proceed with the assumption that the controls are 24vac.
Depends on how the thermostat is communicated with and how it interprets the information its getting. Could be a real in depth problem, like low refrigerant or low air flow. Both of these problems could be caused by a fan not running when it should, or shutting off when it should not or a dirty filter.
If it doesn't have a "code" telling you any information then its locked off most likely.
First lets see if we can narrow or trouble down by looking outside and inside units til the problem happens. Assuming you noted nothing to show you any place to concentrate on outside or inside (like both fans run, air filters clean, all duct dampers open... ) concentrate on eliminating the thermostat.
Most important if your system has a special thermostat, room sensor, or more than 5 wires to thermostat are used: You have something that you need a tech on because it is impossible to cover all the bases here.
To eliminate the thermostat as the source of the trouble;
1 Kill power to indoor section as this is where the thermostat gets pow from most often.
2 Make a diagram of the wire terminals and label them and put the colors down as to what colors go where. (Colors mean nothing except to the person doing the installation, troubleshooting, or wiring, so he/she wont get lost and keep things straight. On controls, color could be any color but these terminals on the thermostat can not be they have a reason to be marked.)
Now you can disconnect the r,g, w, and y wires (all of them) Usually only 4 on a simple hvac system.
Now put the wires that were on R Y and G together. Stay close to the indoor and out door units for the time limit that the problem used to have if it doesn't reoccur within the previous lime limit plus time and nothing is noted as to sound or speed or other, Id have to assume its the thermostat because you just did what the thermostat did only manually.
If this helped you trouble shoot or decide your next step please rate ma as high as you can.If you need more please post back with what you found on your tests and what changed or what you noted different.
Thank you for using Fix Ya and good luck.
Posted on Mar 27, 2009
mydogisk
  • 50 Answers
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
Posted on Apr 13, 2009
  • 323 Answers
SOURCE: Intermatic electric water heater timer only gives
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
Posted on May 14, 2009
protek480
  • 1714 Answers
SOURCE: A Nelson controller won't accept programming commands
Look for a 'master reset' in the manual. This should put everything back to 'default setting'. Then start over in your programming. Don't forget to save after you program your parameters.
Posted on Jun 26, 2009
protek480
  • 1714 Answers
SOURCE: Intermatic pool pump timer, time clock won't turn
Check your wiring, it sounds like it's not right. The clock needs 120 volts to run.
Posted on Jun 30, 2009
Getting sprinklers to come on
Is it a one way valve? If so you may need to turn it around, if it was just installed from new... make sure that the dust caps are not inside the valve and obstructing the line
Jun 02, 2016 | Orbit Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
No AC fault in Orbit Sprinkler Timer Model 57896
Call Technical Support at Orbit. The 800 number should be listed in the instructions.
Apr 17, 2014 | Orbit Underground 57896 6 Station In/Out...
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Sep 10, 2012 | Hardware & Accessories
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Aug 09, 2012 | Orbit Hardware & Accessories
Directions for GreenThumb watering control by Orbit model 27157
Copy following links for Orbit timer manuals & sprinkler timer manuals
Jun 08, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Hardware & Accessories Logo
168 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
