Question about Heavy Duty Tools & Hardware - Others
NO PROBLEM BUT THINKING OF BUYING A SECOND HAND DYNAMIC D90 NAIL GUN,ARE PARTS AND SERVICING EASY TO FIND
  • 382 Answers
What country are you in? I'm in Canada and there are no parts around here.
Basically if its not a Hitachi, Max, Pasload or Bostich don't even think about it.
Posted on May 08, 2010
Where to find non-marring bumper for arrow et 200 nail brad gun part number 2815
The non-marring bumper for the ET200 nail gun is Part #2815. Send a note together with a check for $1.50 plus $1.00 S&H to Parts/Service Dept., Arrow Fastener Co., 271 Mayhill St., Saddle Brook, NJ 07663.
Mar 26, 2013 | Arrow Heavy Duty Nail Master Electric Brad...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
My Hitachi nv65ah nail gun won't set nails into 3/4 trim. I have played with the turn/screw set adjustment and it is set for the deepest setting. This gun was purchased second hand off e-bay but
If every nail is stopping at the exact same height, a likely reason is the tip of the driver is broken off so it's not long enought to drive the nails all the way to flush. If the height of the nails is slightly different you may have worn or broken o-ring(s) inside the gun and air is leaking around the driver's piston or elsewhere in the gun so that the driver isn't getting full pressure. You can take the gun apart and inspect the o-rings. If you push the driver all the way down the tip should come flush or slightly past the end of the nose piece (not the safety tip). Parts are easy to find online or at a service center if you have one nearby.
Mar 10, 2012 | Hitachi NV65AH 212Inch Coil Siding Nailer
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
How do i put the nail pusher spring back in the hitachi framing nail gun
Remove all bolts holding the rails to the body of the gun (make note of the position of the parts as you take then off ). Slide out the pusher assmbly. If the spring is good (wound tightly and has the bolt hole), hold the pusher assmbly in hand and attach spring to body of gun leaving bolt loose. Slide the pusher back into the rails and attach rails to body of gun up against the bolt (snug down bolt and check spring action). Re-attach rails to gun. Some after market rails do not have the slot cut into front allowing easy install of spring (cut slot with dremel). Good luck
Sep 12, 2011 | Hitachi NR83A2S Framing Nailer, Full Head,...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Where can i buy batteries and a charger for my dynamic d90
Jegs11 Keynexions on eBay UK has mains-adaptors and car power-leads for The Dynamik D90S (gas-powered nail-gun); EU 2-pin, US/CA 2-pin, AU/NZ 2-pin, UK/IE 3-pin, as well as the universal car cable. They do NOT stock the actual charger-base though...:
http://stores.ebay.co.uk/Jegs11-Keynexions/_i.html?_nkw=d90s&submit=Search&_sid=58583447
Aug 21, 2010 | Dynamic Arrow Fastener Co. T50PBN Staple &...
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Nail gun- double feed
Nail guns either have a switch or a seperate trigger assembly for two options - automatic, or 'bump' fire, and sequential fire. Sequential firing may be best for you since the nose must be fully depressed and the trigger pulled for each nail.
If you're stuck with bump firing, practice your technique. Double fires often occur when the workpiece bounces back into the nose of the gun; learn to 'bounce' the gun off the material to avoid this second contact.
If you're getting double fires in sequential mode, the problem could be more serious. I keep a can of aerosol silicone lubricant on hand to clean and lubricate the feed mechanism and magazine. Make sure your tool is clean and lubricated before each use, including the 3-5 drops on the air coupling.
Check that your air pressure is not set too high. Overdriving nails reduces their effectiveness and can cause tool malfunction.
This problem could also be caused by worn out O-rings or other parts within the tool. If you're not comfortable servicing the tool yourself, take it in for repair/maintenance work.
Another important thing to remember: With tools like this, you get what you pay for. A cheap nailgun will never function as well as a quality nailgun.
Oct 14, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
123 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
