Question about Kenmore Elite 45986 Front Load Washer
Some one used the wrong soap not the he suds. It flashed a f 71 code then it went dead. nothing works and sears don't help any.
  • 185 Answers
Try unplugging it wait a few minutes then plug it back in
Posted on Mar 27, 2008
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
An error code keep coming up. sud reads on the display instead of time, and clothes are not done still wet
The part is call analog pressure sensor switch . And you are using the wrong soap for the machine
Oct 18, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Error code "SUD"
SUD error means there is to much soap being added, the washer will shut down, if it cents to much soap
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Is not draining suds or F on screen
Suds is a warning that you are not using He "high efficiency" detergent, or too much soap, the F code should be followed by a number, more than likely your problem will be solved if you fill and drain the machine a couple times with no soap and use very little He soap when washing (3 tablespoons).
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washer flashing F then went to SUD
Drop the drain hose so that it is lower than the drain and let all the water run out of the machine. Open the door and remove all washing. Let machine go through rinse cycle with some milk mixed in with the water, (pour the milk into the soap container, about one cup) and make sure there are no soap suds left in the machine. Check that you are using washing powder which is recommended for front loaders.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
170 people viewed this question
Sal De
 Brian Main
Brian Main
