Question about Panasonic Panafax DX-800 Plain Paper Laser Fax
Faxes aren't being forwarded
Our fax is set to fax forward faxes to an email address. For two days, the faxes aren't being forwarded. I don't know where they are. I would like to a) find them b) or set the fax to just print on paper, but can't find out how in the manual.
    Sergeant:
  • 284 Answers
To try to find out where they went check your fowarded email address. check your parameters in function-7-1-start then scroll down.
to shut down fax foward the other person was right function-7-4-start-5-4-start-1"invalid"-start-stop
any other questions feel free to ask.
Posted on Sep 11, 2008
    Genius:
  • 2,120 Answers
Function 74 set
54 set
1 for invalid set
stop
Posted on Aug 31, 2008
SOURCE:
How to Forward this fax to another fax
try *21{other fax phone number}#
dial it into phone line when off hook
then #21# to turn off
Mar 07, 2018 | Toshiba E-Studio 170F Fax Machine
Hi,a want to forward a received fax to a email address with a hp m5035mfp,is it possible?
Yes you can, what you need to do is go into the embedded web server (type in the IP address of the printer into your browser). The function you need to turn on is called Fax Archiving. This will then use the email function of the 5035 to forward the mail to the address of your choice.
Apr 19, 2011 | HP LaserJet M5035 MFP Printer
Can winfax pro automatically foward faxes to an eamil address. I am not home to look at my faxes and would like to have them automatically forward to an email address
yes, it can automatically forward your faxes via e-mail using Outlook or Outlook Express.
See Notification & Forwarding options. You also need to enable Outlook Integration option in WinFax.
Jan 22, 2011 | Symantec WinFax Pro for PC
I want to forward my faxes from my Panasonic machine to another # temporarily.. is this possible and how?
Fax forwarding You might want to set up fax forwarding if you are going on a trip, but still want to receive your faxes while you are away. There are three fax forwarding settings:
  • Off (default)
  • Forward-When your All-In-One receives a fax, it holds it in memory and then sends it to the fax number that you designate.
  • Print and Forward-Your All-In-One forwards the fax to the designated fax number and prints the fax.
To set up fax forwarding:
  1. On the control panel, press Fax.
  2. Press Options until Fax Forward appears, and then press Select.
  3. Use the arrow buttons to scroll to the option that you prefer (Fax Forward or Print and Forward) appears, and then press Select.
  4. Enter the number that you want to forward the fax to, and then press Select.
Fwd now appears on the bottom left corner of the display.
Dec 16, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Problem with fax on estudio 3511
When enabling the Offramp Gateway, this equipment works as an SMTP server to receive
Emails from the Internet. To enable the STMP transmission in this equipment, designate the hostname (or specific domain) that relates to this equipment in the DNS server, and designate the MX record to receive the Emails that are sent to the equipment’s domain in the SMTP server in your local area network. Then the SMTP server should be configured to transmit the received Emails to the equipment in the SMTP transmission. For example, if the hostname of this equipment is designated as “host1.ifax.com”, the SMTP server receives an Email whose forwarding address is “<account name>@host1.ifax.com”, and the SMTP server transmits the received Email to the equipment. Then this equipment will send the received Email as a facsimile document to the fax number that is specified in the <account name> part.
Setup Procedures:
1. Setting up the DNS server and SMTP server.
2. Setting up the TCP/IP and the HTTP Network Service to enable TopAccess
3. Setting up the SMTP Network Service.
4. Setting the Internet Fax Settings.
5. Setting up the Fax Settings
6. Registering the Relay Box with Email addresses.
Dec 19, 2008 | Toshiba E-Studio 161 Copier
Panasonic UF-890
Take the swinging drum cover off of the toer cartridge and throw it away. It's only for shipping. They come loose and block the paper path.
Put the number you want to forward to in a one touch number position. (if you have to dial 9 for an outside line, be sure to put that into the one touch number also).
Function 74 set 54 set 2 for valid set stop.
Answer to last question, probably...not.
Aug 28, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Resending Faxes
This is possible. there are several requirements though.
youe first option is if you have two multi-function devices cable of sending and receiving e-mail. If you do, set the iR3320 up to forward the faxes to an e-mail or i-fax address (another name for a e-mail address). Set the other machine to receive the e-mails sent to the previously mentioned e-mail address.
Your other option is to set the iR3320 up to forward the faxes to a folder on a computer. In this case you can open and view the faxes and if you want them on paper, send the job to another printer.
This setup is rather tricky, so unless you have a really really really clued up I.T. guy, i would recommend that you have a Canon technician set this up for you.
May 06, 2008 | Canon imageRUNNER C3220 Color Copier
Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Nov 04, 2007 | Brother MFC-8860DN All-In-One Laser...
Panasonic Panafax DX-800 Plain Paper Laser Fax Logo
170 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
