Question about Garden
Do i drill holes in the sump pump basin - Garden
  • 1,284 Answers
Hi, yes and i suggest you dig the hole deep enough to set the basin on some 1.5" thick "patio blocks" for support..
Take care
Posted on May 08, 2010
Pump continuosly runs after water is cleared out of basin
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Mar 24, 2014 | Hydromatic Pump Hydromatic V-A1...
What does f05 mean on a hotpoint washing machine
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
May 20, 2012 | Hotpoint Washing Machines
Eroor code on my hotpoint ultime wt746 = F - 05
Jul 11, 2011 | Hotpoint Washing Machines
Fault Code F5 is flashing was on washing cycle and has stopped on this -
from,
hotpoint ace
Jul 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wma 32 - machine will not empty wayer and spin! How can I fix this problem?
Jun 25, 2011 | Hotpoint Washing Machines
Oil will not feed to chain.sump is full.
The out let hole can get plugged with sawdust. Drain sump,remove chain and bar.Wrap a clean rag around a compressed air nozzle and pump in some air,not recommended for plastic sumps.You can use a piece of wire or a small dull drill bit or a torch tip cleaner from a welding supply.
May 09, 2011 | Garden
The f-05 is flashing up on the LCD screen and washer won't spin just stops.model is wd860
Apr 25, 2011 | Hotpoint Washing Machines
Hotpoint wma66. programme finishing too quickly and water not emptying from machine
does f-05 come up on the display?? if so
Feb 20, 2011 | Hotpoint WMA66 Front Load Washer
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
