Question about Graco Imonitor Digital Baby Monitor
Receiver will not pick up from base station
We have a Graco iMonitor baby monitor and my wife dropped the receiver on the porch. The receiver will turn on but the charge lights and volume lights stay red. When on the charger the charge light is green but then if you turn the receiver on while on the charger the charge light is red and the volume light has one green and one red light. Any suggestions?
I have bought two graco monitors which are the same and they interfere with each other- help?
There should be different channel options (A, B, C or 1, 2, 3) Have one set on A or 1 and the other set on C or 3. That should reduce interference. Hope this helps :)
Aug 21, 2011 | Graco Imonitor Digital Baby Monitor
On the front of the monitor all lights are green besides the very bottom one is red. what is wrong
that happens whe the receivers loose the communication with the transmisor
check if everything its well connected or has battery charge
Mar 26, 2011 | Graco Imonitor Digital Baby Monitor
We got a new monitor sent from graco (which had nothing on the screen) but now the new one will not pick up the signal from the camera ? Have you then info to pair the two devices ? Thanks
hi firstly can you check the powersupply that came with it make sure it is powering up and transmitting if you have a multimetre you can check it with this,check the batteries if there are in this model make sure you have power coming from the powersupply and check connections hope this helps you cheers
Mar 16, 2011 | Graco imonitor Digital Color Video Baby...
My monitor ( imonitor Digital Color Video Baby Monitor) only connects with the power turned on and the button pressed
Try rebooting the system, if it is within the warranty I would contact Graco or the store you purchased it in!
Feb 28, 2011 | Graco imonitor Digital Color Video Baby...
I have the dual graco baby monitors which I love and want to salvage. They weren't cheap. They have brand new batteries in them which I had to have made. You can tell the batteries work, they turn the...
You might have to pair the parent units to the base units. here is the manual, look under troubleshooting:
http://ubermanuals.com/product/graco-multichild-2794dig1-1069
Mar 16, 2010 | Graco Monitor 2794Dig Imonitor Dual
Battery replacement
I am wondering if you located one, I have the same issue. Thanks!
Nov 16, 2009 | Graco Imonitor Duo Baby Monitor
Static interference problem
The Graco digital iMonitor scrambles the signal as it travels between the monitor and the receiver, making signals nearly impossible to be heard by others.
I had good experience with this product, it didn't suffer from the static noise problem.
Jul 16, 2009 | Graco Imonitor Digital Baby Monitor
Graco Imonitor Digital Baby Monitor Logo
1,077 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
