Question about RC Xrc Gas Rc Car Scooter
49cc Pocket Bike Carburetor Won't Draw Fuel
The motor fires up briefly when I manually inject fuel through the throat
of the carb. Will not fire up otherwise. I have completely cleaned the
carb twice. I siphoned the fuel line to make sure that the fuel is available
at the carb fuel inlet. I also have purge pumped the carb (repeatedly pressed the plastic bulb at the bottom of the carb). I have been working
on small engines for many years, but this one has me totally at a loss. Any suggestions?
    Problem Solver:
  • 19 Answers
First off, are you getting fuel to bulb? if not are you sure the lines aren't on carb backwards. if you are getting fuel to bulb and won't run then here's what i'de check. how's the compression, may not be making enough vacuum to draw fuel, have you removed the mixture screws and blown out passages, there is a little sreen under diaghram in some of those little carbs that gets clogged, carb base gasket?
Posted on May 18, 2010
My x7 pocketbike does the same thing so Im going to try this solution as soon as i get home
Posted on Sep 18, 2012
Toro Z will not start but turns over. Getting fuel and spark. Motor will crank without setting in seat. Break is on, PTO is disengaged and both levers are in netural.
Timing or stuck valve. If it is indeed getting fuel into the cylinder. Try directly squirting a small amount of fuel into the carb throat. If it then actually fires off you know the carb needs a cleaning. Be careful though as if it happens to backfire it can try to catch fire.
Jul 29, 2016 | Toro Used 60" Z Master Professional 5000...
Suzuki gsxr 750 slingshot cranks but wont start.
For a motorcycle engine to run you need compression, ignition (spark) and fuel. Quite often with a bike like a Suzuki if the plugs get even a little wet but otherwise look like great plugs, the motorcycle will not start. So, new plugs are a good place to start, however if you put in new plugs and try to start a few times and have fuel but no spark the new plugs may become unable to start also.
FIRST check to see it you have spark at the spark plugs, then remove the plugs and either do a compression test with a gauge OR put a finger over the plug hole and turn it over and if you have adequate compression the engine will blow your finger off of the hole when it comes up on the compression stroke.
If you have a carburetted bike you can check for fuel by taking off the air filter and operating the throttle a few times full open in which case the accelerator pump should eject a spray of fuel into the carburetor throat. With Carb or Fuel Injection you could also spray some fuel into the carb throat or the induction module throat while turning the engine over with spark at the plugs. If you have spark and compression but no fuel th eengine will fire when you spray the fuel into it.
Sep 20, 2014 | Motorcycles
Cranks and fires but wont strats
Hi Anonymous, sounds like you have a fuel pronlem. Check fuel flow to carb, check fuel filter remove air cleaner and squirt starter fluid or Brake Kleen into carb throat, if it fires up and runs for a few seconds then you have a carb problem. Remove carb and bowl clean clogged jets and air passages, and clean bowl. Visit website below to download cheap ( $5.50 ) service manual that will walk you through it and also trouble shoot:
Harley Davidson Manuals Mark Workshop
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2014 | 1979 Harley Davidson XLS 1000
Engine won't start- I have changed gas, I have a good spark, and no air blockages
Put a nice new spark plug in the engine and clean the carb with carb cleaner. Spray some cleaner in the carb throat, and put some liquid carb cleaner in the fuel tank.
Mar 05, 2014 | Troy-Bilt Super Tomahawk Chipper Shredder...
Turning over but not firing
What year and is it carb or fuel injection? Chances are you have a carb model as fuel injection rarely gives this problem. Check choke operation on the carb. Assumes all other areas o/k, that is battery, ignition, starter motor etc. as a slowly turning motor is harder to start when cold.
Dec 28, 2013 | Harley Davidson FXD Dyna Super Glide...
Scag zero turn 52"deck tiger mower
If you have spark, compression, and fuel to the carb but not at the plug. You have a clogged carb. Try starting with starting fluid, if it fires briefly, your carb needs to be removed and cleaned.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 03, 2013 | Garden
My 2002 polaris trailblazer wont start it has fire
If you have oil and gas and it will fire then try a new plug. A bad plug when removed will appear to be fine but under compression can fail.
Also try a splash of good gas in the throat of the carb or intake (if fuel injected) with a new spark plug. My bet is it fires just fine.
If this is a fuel injector type engine you could have a bad injector control unit or a clogged injector.
If it fires with gas in the intake manifold then suspect carb or injector system. (which ever applies)
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Polaris ATV
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
94 Lumina van will not start UNLESS...
At the carb fuel intake there is a fine screen to keep the debris that might form in the fuel tank out of the carb. It sounds like that might be the problem.
Nov 05, 2009 | 1994 Chevrolet Lumina APV
1994 Chevrolet s10 will not start. The starter, battery, and alternator are good. Could it be the eprom chip or a fuse or something else electrical?
its lack of spark, or lack of fuel. Dribble some fuel into the open carb throat whilst cranking, if it fires even once, then spark is ok
if you have fuel injection it could be a bad throttle body injector. Spray methanol from a squeeze bottle into the open throat, if it fires even once, then its lack of spark
Dec 19, 2008 | 1994 Chevrolet S-10
RC Xrc Gas Rc Car Scooter Logo
1,529 people viewed this question
Top RC Tools & Hardware - Others Experts
john h
Are you a RC Tool and Hardware - Other Expert? Answer questions, earn points and help others
