Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer will not come on and all the lights are lite up on it.
My dryer will not work and the lights are on what is the problem
Posted on May 13, 2010
Put in new ignator will not lite
Did you follow installation instructions on the ignitor? The pilot light may have gone out. Try turning the gas off to the dryer for a couple minutes and then following the pilot light lighting instructions for the valve assembly. Youtube has many good videos on this as well.
Dec 01, 2014 | Maytag Dryers
Kitchenaid ensemble dryer won't start and panel won't light up but light is on inside when you open
If it is a electric dryer not gas then something simple to check would be your breaker box to make sure one side of your dryer breaker has not tripped because that would allow the light inside to lite up but nothing else. I had one leg of the 220 outlet go bad at a freinds house .... kind of unusual but it does happen.
Jun 08, 2014 | Dryers
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
I think my pilot light went out, but I need to know how to locate it
Dryers do NOT use a standing pilot lite ..When the unit is turned on and heat is commanded on the gas valve opens and an igniter lite's the gas , then their is a flame sensor to see the flame from the burning gas if no flame is present it shuts the gas back off.. So if you have a no heat concern with your dryer it will be either the igniter, gas coil's or the flame sensor
Jan 03, 2011 | Dryers
How do I lite the pilot, where is it located on Whirlpool Dryer Model LGQ8857JQ8?
Your dryer does not have a pilot light. It has in igniter. What kind of problem are you having with the dryer?
Dec 31, 2010 | Whirlpool LGQ8857J Dryer
The flame won't light everytime I turn the dryer on I have to turn it on and off a couple times to get it lite. And when it don't lite I hear a buzzing noise that I don't hear when it its lit.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 14, 2010 | Amana LGA10 Dryer
Im trying to lite the pilet
This dryer has no pilot light. When you turn dryer on the igniter turns on and lights gas. If yours is not igniting, you could have a bad igniter or a bad heater cavity switch located behind back panel attached to dryer vent area, has two wires connected to it.
Jun 10, 2010 | Estate TGDX640JQ Gas Dryer
Maytag quiet series 100 electric dryer clicking when I try to start. Pause light clicks on too.
my dryer clicks on then runs for 30 sec then clicks off and all the lites flash then it stays on the regular lite
Jan 30, 2010 | Maytag Dryers
Gas dryer works but no heat
have you checked to see if the pilot light is lite.
Mar 24, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
