Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam us 144
Does not give sound through my computer or record onto cubase LE
  • Ria77 May 12, 2008
    I have exported song from Tascam to my PC with USB open on the Tascam, however when I click into the DP 01 on my computer, open the WAV file and play the song, there is no volume at all - do I need specific software on my PC in order to get volume for WAC files transferred from the DP 01
    Sergeant:
  • 243 Answers
Make sure you select it as the interface device in cubase.
Thanks,
Nate
Posted on Aug 22, 2008
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
Can't get a signal with my Tascam US-144
Make sure the Tascam is has updated drivers. The latest driver is Version 1.12. Something that helped me as well was to re-route my sound card to the Tascam. Meaning to have Windows, use the Tascam as the sound card for the computer.
This is the advice I followed from a forum it helped me alot!
I eventually disabled all other sound cards on my PC. In my case it was simply the integrated soundcard on my motherboard. I did this in the bios setting. I also uninstalled the drivers for it, just in case. I was having problems hearing anything in Cubase before I did this.
I set the US-144 as my default sound device in Windows (Control Panel>Sounds and Audio Devices>Audio)
I'm not sure what you are trying to record so I will give you a guitar example.
Guitar plugged directly into LINE/GUITAR IN R using the 1/4" jack with the switch above it in the GUITAR position. You can use the INPUT R dial to adjust the input volume for this channel. The SIG/OL light should turn green when you strum the guitar.
The US-144 is plugged into a USB 2.0 port on the PC.
Speakers are plugged into the LINE OUT jacks on the back of the US-144. The MON MIX dial will adjust what goes out through these jacks. If you move the dial all the way to the left, you will hear the input from the guitar directly from the US-144. If you move the dial all the way to the right, the signal goes through the US-144, into the PC via the USB connection, then back to the US-144 through the USB cable, and then out through the line out jacks. You may not hear anything when it is all the way to the right until you have Cubase open and configured properly. IMPORTANT NOTE: If you have MON MIX dial turned all the way to INPUT, you will not hear anything being output from your computer.
The LINE OUT dial adjusts the volume through the LINE OUT jacks. Make sure this isn't turned all the way down.
At this point, you should be able to turn the MON MIX dial all the way to INPUT and hear your guitar. It will probably only be coming out of the Right speaker, which is what it should be doing. Now turn the MON MIX dial back to somewhere in the middle so you can hear both the input from the guitar and your PC.
I downloaded and installed any updates that were available for Cubase LE 4 (I think all I needed was the 4.1.3 hotfix).
In Cubase goto Devices>Device Setup>VST Audio System and choose the US-122L /US-144 ASIO driver from the pull down menu. I'm not sure how important the "Relase Driver when Application is in Background" checkbox is, but mine is unchecked. If you click on the US-122L / US-144 section, you will see a button for the Control Panel. It will tell you what your driver and firmware are and what USB mode you are operationg in, etc. I didn't mess with any of these settings, but it is good to know how to get there. You should also see all your in's and outs. I have 2 analog in's and out's and 2 digital in's and out's. I am only using the analog in's and out's. Hit OK to close out this menu.
Now goto Devices>VST Connections and you should get a new window. There is an "Inputs" tab and an "Outputs" tab. Under Outputs, you should have a Bus for Stereo Out using the US-144 as your Audio Device and the US-144 Analog outs for the device ports. Make sure the "CLICK" colum is checked if you want to hear your Cubase metronome through your speakers. If you don't have a bus, add one and set it up as I have described.
Now goto the Inputs tab and add a mono input using the US-144 analog in R as the Device Port.
Now start a new project and add an Audio track using the Mono in and stereo output. Use the Edit Channel Setting button if you have to change your input and output.
Now with the MON MIX dial all the way to the right and with the Monitor button enabled on your audio track, you should be able to hear your guitar through Cubase.
Now if you turn on the Record Enable Button on your track and then press the Transport Record button, you should be able to record your guitar. Hit stop and then go to the beginning of the track and hit play. You should be able to hear what you just recorded. Don't forget that if the MON MIX dial is all the way to the left, you won't hear anything from your computer.
Well that is my Cubase LE / Tascam US-144 Getting started guide written by a newbie for newbies. May my pain and suffering alleviate some of yours. Good luck.
Dec 26, 2008 | Tascam US-144 Sound Card
Tascam US-144 problems with ableton live and in general
Im using Vista on a Sony Vaio FW11E with Core 2 Duo Processor. 3Gig ram. Its not working properly with me either. Its a loan of a mates. Ableton and Windows Media Player just keep stopping for a second every few seconds! Very annoying!
Sep 28, 2008 | Tascam US-144 Sound Card
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
No Inputs detected in Cubase
have you checked to see if the inputs are the Tascam
and the outputs are the Tascam i had the same issue when i first got it have a look in them settings and just see if there the defaults
Jan 28, 2008 | Tascam US-144 Sound Card
Cubase software does not recognize my TASCAM US-144
do u have usb 2.0 prts in back use not front of pc those 1.1 ports ok cheak drivers on all tell your master sound drivers defult to tascam see what happends
Jan 15, 2008 | Tascam US-144 Sound Card
Tascam DP01 All-In-One Recording Package Microphone Logo
99 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
