Question about Kenmore 44102 Front Load Washer
Clothes are coming out with dirt marks all over them all of a sudden. How do I fix this?
    Problem Solver:
  • 10 Answers
If your getting grease like dirt on your clothes the problem is the water seal on the rear bearing is probably shot. Unfortunately this is expensive, as it may require the entire drum to be replaced. I hope you can go with out washing for 1.5 weeks. The entire drum assemblly needs to be removed and then the 2 halves seperated. If your lucky you'll just need the back ($200) If you need both its $550. I would suggest replacing the shocks, while your at it.
Posted on May 09, 2010
2 Suggested Answers
hektor1961
  • 70 Answers
SOURCE: dirt marks on clothes from dirty rubber door gasket
Unfortunately you need to remove the front panel and change both drum slides to re-align drum again and keep it from damaging your clothes.
Posted on Aug 18, 2009
My Whirlpool super capacity 2 speed 7 cycle washing machine filter is dirty because it makes marks on clothing. Any suggestions on how to fix this please. Thanks Regards George
Hi, sometimes even after cleaning the filter dirt remains in the machine. The best thing that can help solve this problem is to buy a descaling powder for washing machine (available at supermarkets or hardware store) and follow the instructions on the box or packet, this will take awhile as you will have to stop the cycle by turning the power off when the machine is full of water (with no clothing in it) and then restart the cycle, (about 2 hours). Descaling is necessary as the soap powder attaches itself on the rear of the rotating drum and cannot be seen and some dirt(streaks) will appear on the washed clothing. Hope this helps. All the best.
Apr 28, 2015 | Whirlpool Washing Machines
Dirt after washing
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 11, 2012 | Fisher and Paykel Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
The dryer dispels sand and dirt after each cycle- I think it needs to be cleaned?
do you see marks on your clothing if not the problem may not be with the dryer but the washer. do you live in a sandy area? with kids check the pockets of item before washing generally not a very good chance of dirt or sand coming from the dryer
Aug 19, 2009 | Frigidaire Dryers
Dirt marks on clothes from dirty rubber door gasket
Aug 18, 2009 | Kenmore Washing Machines
Front loader leaving black marks
had the same problem. Tried changing the washing powder to no effect.
Jul 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Kenmore 44102 Front Load Washer Logo
142 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
