Question about Dynasty DGRSC 36-5WOK Gas Kitchen Range
Three of the burners don't work.
A pot in the middle boiled over with salt water and now I can't turn on the back 2 and the front left burners.. Help please... I have 30 people coming over tomorrow.
  • 250 Answers
Basically, the electrode that causes the spark to jump from it to the gas ring/top is shorting out because of the water. It has to be bone dry and clean for it to work. With the rings off, make sure they are dry and use say kitchen towel to clean and dry the electrodes. Be careful, the electrodes are fragile and will not take any punishment. If in doubt you could use a hairdryer to dry the electrodes but do not have it too hot - the force of air alone may be sufficient to clear away the dirt and damp.
Watch the spark on the one that does work to see what it should do!
Posted on May 08, 2010
Correct way to boil an egg at 9000 ft
Your elevation shouldn't be an issue but a pressure cooker could help. Add a tablespoon of club soda to the water.
Dec 01, 2017 | Ice Kitchen Appliances - Others
Whenever I cook pasta the water boils over and causes a terrible mess. How can I stop this happening?
The most common cause of water boiling over when you cook pasta is if you cook it with the lid on the pot. Don't cover pasta fully with a lid. Either cook it uncovered or if you are in a hurry to cook it quicker, just partially cover the pot.
Also make sure you don't overfill the pan with water as this is another cause of overboiling.
Jan 10, 2013 | Cooking
The flames from the front left burner is 1/3 orange and 2/3 blue; whereas the flames from the other burners are all blue. There is a strong odour from the front left burner when we turn it on and also the...
The flames should be all blue - except when you first turn it on, where the flame begins, & only when you turn it on. Orange flames mean incomplete combustion is happening. Carbon monoxide is being released. Orange flames can also mean your getting low on gas. Clean it & try moving the disk around. An uneven disc means some flames will be higher & burn your pots. The flames are wrapping around your pots if they're burning on the sides. Keep flames under the pot. Regardless of the being clean, the odor means you need to check your gas level. Once filled back, the odor should be gone if that's the only problem. That is placed in the gas as a safety feature. Don't try to fix this problem yourself if the "easy" solutions don't work. It could be very dangerous. Invest in a carbon monoxide detector especially when you have anything gas.
Sep 15, 2011 | GE Profile JGS968 Gas Kitchen Range
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
Mar 19, 2008 | Salton RA3 3-Cup Rice Cooker
Vintage Revere Ware Copper Clad 8 Cup Drip Coffee Pot
Barbara,
Coffee grounds go in the top. (i use a filter paper also.) Install baffle with stem up. Assemble top to empty bottom section. pour boiling water into top. I use 4 cups water, 2 scoops chickory coffee. Let water trickle down into bottom. I put mine back through 3 times, black as tar. That is the advantage of this machine. I will never use another.........
Mar 11, 2008 | Kitchen Appliances - Others
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Bummer Bun
The pour-over type of Bunn coffee brewers require several pots of water to fill an empty tank.
1. While unplugged, pour in two and a half to three pots of clean water (put an empty pot underneath the brew basket). When the tank is full, water will come out of the brew basket.
2. Plug the unit in and wait for it to heat - about 5 to 7 minutes. These brewers are meant to be left plugged in all of the time to keep the tank water hot. You will probably heat some rumbling noises which is normal as the water heats.
If for some reason the water isn't hot after 10 minutes you will need to check the thermostat. Unplug the machine and take the screws out of the top. The thermostat has a little dial or a t-bar that you can turn. All the way left is off and all the way right is boiling. Turn this up about 90% of the way and put the top back on the machine and plug it in. If it gets hot, you are ready to brew. If it doesn't get hot, you may have blown the limit thermostat and will need to replace it.
The limit thermostat isn't the same as the thermostat. It is a ceramic and metal item that senses if the tank gets too hot from having the unit plugged in without any or enough water in it. It is inexpensive and relatively simple to change.
Nov 25, 2007 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
Dynasty DGRSC 36-5WOK Gas Kitchen Range Logo
80 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
