Question about Apple PowerBook G4 Mac Notebook
My Powerbook G4 turns on light, fan, chime but no video.
The lit screen flashes a small folder icon with a tiny face and a question mark in the center.
I tried the manufacturer's suggestion to reset it, (control command P and R all pressed at the same time, wait for second chime then release), did not work. What I hear after the first chime is a knocking 3-4 times. Then the lit screen becomes black and lights again to the above ( flashing folder-face-question mark)
When I insert the Install CD I see video. When I remove it, there is no video.
- Help Please! - Help Please! - Help Please! -
    President:
  • Apple Master
  • 1,619 Answers
Your hard drive has lost a file needed to start up the machine. The folder with the question mark means it cannot find a useable Operating system. I hope you backed up your files you needed becuase the only real way to recover the machine is to reinstall the OS from the install disk. You must format the Hard Drive from the format option on the install disk and reinstall the OS.
Posted on May 08, 2010
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
Turn on my powerbook G4 but there isn't a chime and nothing comes on the lcd screen
If there's no chime, your problem could be anything from a dead battery or bad AC adapter to a dead logic board.
Does the tip of the adapter on your AC connector light up? If not, that's a problem.
When you push the button on the battery, do you get at least two glowing LCDs? If not, that's a problem.
Otherwise, try the following: remove the battery and the AC jack to make sure the machine is off. Now insert the AC jack, and reset the power management unit by pressing the following multi-key combination:
Shift Control Option Power-button
Wait five seconds, then press the power button to attempt to start the computer normally.
The instructions above are for the 1.5GHz PowerBook G4; the instructions MAY be different if that is not your model.
Nov 01, 2010 | Apple PowerBook G4 Mac Notebook
My Powerbook G4 has light,fan,chime on but video.
try booting with control command P and R all pressed at the same time, wait for second chime then release.
May 07, 2010 | Apple PowerBook G4 Mac Notebook
Laptop not turning on properly
your hdd gets corrupter.Try reinstalling the softsre ahain.
Apr 16, 2010 | Apple PowerBook G4 Mac Notebook
My mac powerbook is displaying a folder which flashes between a question mark and a icon in the middle of the folder it stays on the grey start up screen and doesnt start up any suggestion???
Your PB can't find the system. Most likely you hard drive is no longer working. To check that this is the case, start up from the discs that came with your computer.You will need to replace the hard drive then re-install the operating system off those discs. I hope you had a backup of your data!
Feb 21, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
HELP!!! I am trying to start my Powerbook G4 but as soon as it turns on I just get a grey screen that says that i need to restart my computer. i tried restarting it like 10 times. what else can i do?
Also, check your RAM bay port to see if one of the RAM boards came dislodged and is not inserted correctly. Could also be one of your RAM boards is not compatible or one of the RAM boards is defective.
Jan 25, 2010 | Apple PowerBook G4 Mac Notebook
When I turn on my 17" power book g4 I hear the drive and chime and see a blip of screen light up from the lower right corner of the screen but goes black right away. I have no software at this time. I...
Do you have this machine plugged into AC power? If not, you may just have a depleted battery, which would fit these symptoms perfectly.
The problem is not software related, because with a missing or empty internal drive you would get a flashing question mark folder icon instead.
Does the machine power off when the screen goes black, or does it continue to run with a dark screen? Common solution for the latter is to wait two minutes until the boot sequence sounds complete, then press the F2 button to raise the screen brightness. Failing that, you may have a blown-out backlight tube in the screen itself, which can be addressed.
Oct 18, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple PowerBook G4 Mac Notebook Logo
982 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
