Question about GE GSS25SGSSS Stainless Steel Side by Side Refrigerator
My GSS25SG Refrigerator is leaking from the freezer side on the bottom. Please advise on how to fix it.
    New Friend:
I have similar issue but it is in the back on the refrigerator side
Posted on Aug 06, 2017
  • 237 Answers
SOURCE: My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
Posted on Feb 08, 2007
  • 1314 Answers
SOURCE: refrigerator freezer leaking
your defrost drain is frozen or has algae blocking it its at the back of the freezer behind the evaporator cover. You can see it without removing the evaporator cover. You might or might not see the drain hole because of the ice now you can sit and poor hot water on it till it thaws then get a thin wire and run down the tube till its clear or sit there with a hair drier and thaw it .But if you don't mind a small investment ill tell you the best way to deal with it .Go to Lowe's or some where like that and buy you a eureka model 350 hand held steamer.Trust me it will be one of the best investments you'll ever make. You will find 1001 uses for it besides this and the steam will not damage your refrigerator and all the attachments make it very useful.remove the evaporator cover and take the steamer and melt the ice under the evaporator where the drain pan is. Then you will see the drain hole.Put the curved tip on the steamer an start clearing the drain hole now when you get it melted enough to where the curved tip makes a seal around the drain hole let the steam build then hold down the trigger till you hear it at the back of the refrigerator and your done put the evaporator cover back on then think of all the other uses for that steamer now I told whirlpool about it they tested it and now have it posted on their web site that will fix it easy. I hope this is good enough for a four box rateing lol
Posted on Jan 11, 2008
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
I have a whirlpool side by side model # ED5VHGXMB10. It leaks water into the bottom of the freezer. I have re adjusted the water tube that dumps water into the ice maker thinking it was shooting over the...
Below that panel in the freezer (evaporator cover) is the drain trough. Most likely it is clogged.
Using a baster, with hot water and bleach mixed deluge till it flows down to the drain pan underneath.
Dec 31, 2010 | Whirlpool ED5VHGXM Side by Side...
Ice is forming in the bottom of my side by side fridgedaire freezer and once its 1/4 inch thick starts to melt and leak from the freezer onto the floor. I then take out the ice built up and the process...
The drain is either frozen or plugged...when the freezer coil defrosts the water has no place to get away...
Find and fix the drain and you will be okay again...
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Nov 16, 2010 | Frigidaire FRS3R5EMB Side by Side...
The bottom on the freezer side has water leaking and it freezes on the bottom floor and leaks on to the outside floor
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
Aug 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Maytag side be side model msd2454gr
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
Aug 11, 2009 | GE Monogram Side by Side Refrigerator
Leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer door handle loose
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Open Questions:
GE GSS25SGSSS Stainless Steel Side by Side Refrigerator Logo
142 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
